small learning & education infrastructure
504
I am an apprentice in my company and I should design & implement a „simple” infrastructure for apprentices in our company to test out nearly everything they want. For this purpose, I have a room with some racks.
The requirement for the infrastructure is:
  • Each bookable subnet should have access to the print- & file server.
  • The subnets should not interfere with each other. For example when one is creating a domain controller, the other subnet/network should not be affected by this.
  • Each subnet should have its own router. This is for learning purposes because, we can learn how to specify different settings (If this wouldn’t be the case, I’d use a level 3 switch
  • Content filtering should be activated
  • Optional: With each router and it’s subnet, a VPN connection could be implemented
I am thinking of using a Cisco ISR 892W as the main gateway/modem/router/firewall.
http://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-519930.html
And for the sub routers I’d implement a Cisco RV 180 VPN router.
http://www.cisco.com/c/en/us/products/routers/rv180-vpn-router/index.html
I have designed a quick network plan.
Now I have some questions for the realization of this project:
  • Do I need to enable “1:1 NAT” and when yes, which impact does it have for the network?
  • What do I need to configure that the subnets can communicate with the servers?
  • Is it possible, that the « Administration PC » in the 192.168.0.0/24 network can access the subnet to remote administrating the servers (for example over RDP or another technology). When yes what do I have to configure? Static routes?
  • When I am considering implementing a VPN connection for each sub router, is this possible? Are there some issues with NAT?
  • Do you have any other tips for me?
I'm still learning the whole networking sphere and would be happy if you can help me out
Many, many thanks
