SSH and banner login
12790
I currently have a login banner set on my routers.  The problem I'm having is that it only shows up after you enter in your user name and I would like it to show up before.  From what I can find Cisco docs. says it should show up before.  any suggestions on whats going on and how to correct it?
Community Member
banner login # Authorized
Personnel Only! Please enter your username and
password. #
Hey Edwin,
I think this might answer your questions:
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml#banners
Thanks and Regards
Pronoy
Enthusiast
Use "banner motd" instead.
Beginner
I've had problems using MOTD banner on 6500's before where it only came up after login. Changed to SSH version 2 and then came up ok before login.
Content for Community-Ad
