Stateful DHCPv6 Relay Configuration Example
41883
    Introduction
    This document discuss with an example how to configure Stateful DHCPv6 in Relay mode. Mostly, while configuring the DHCP, the DHCP server may not be connected to clients directly in practical scenarios due to management reasons.In such cases, a DHCP relay agent serves the purpose relaying the messages coming from the clients and server.The DHCPv6 Relay Agent uses Relay forward/Reply messages to relay the messages between Servers and clients.
    Requirements
    Background
    In this configuration example,the router R1 is configured as DHCPv6 server and R2 is configured as Relay Agent. The routers R3 and R4 are configured as DHCPv6Client.
    Note: All configurations are tested in a lab environment involving ASR 1000 series router as DHCP server and Cisco 2800 series router as DHCP Clients.
    Topology Diagram
    Summary Steps
    Server Configuration
    In Global Configuration Mode
    1. ipv6 unciast-routing
    2. ipv6 dhcp pool <pool name>
    3. address prefix <specify address prefix> lifetime <infinite> <infinite>
    4. dns-server <specify the dns server address>
    5. domain-name <specify the domain name>
    6. exit
    In Interface Configuration Mode
    1. ipv6 address <specify IPv6 Address>
    2. ipv6 dhcp server <server name>rapid-commit
    Relay Agent Configuration
    1. enable
    2. configure terminal
    3. ipv6 unicast-routing
    In DHCPv6 server Facing Interface:
    1. ipv6 address autoconfig
    2. ipv6 enable
    3. exit
    In Clients Facing Interface
    1. ipv6 address <specify IPv6 address>
    2. ipv6 dhcp relay destination <specify destination IPv6 address><interface type>
    Note: Specify a destination address to which client packets are forwarded and enables DHCPv6 relay service on the interface.
    Client Configuration
    1. enable
    4. ipv6 nd route-owner
    1. ipv6 address dhcp rapid commit
    2. ipv6 enable
    3. ipv6 nd autoconfig prefix
    4. ipv6 nd autoconfig default-route
    5. exit
    Configuration
    DHCPv6 ServerDHCPv6 Relay Agent
    DHCPv6 Client
    version 15.0
    hostname R1
    ipv6 cef
    ipv6 dhcp pool test
    address prefix 2001:DB8:11::/64 lifetime infinite infinite
    dns-server AAAA:BBBB:FE10::100
    dns-server 2001:DB8::5
    domain-name example.com
    interface FastEthernet1/0
    no ip address
    duplex auto
    speed auto
    ipv6 address 2001:DB8:10::1/64
    ipv6 dhcp server test
    ipv6 route 2001:DB8:11::/64 2001:DB8:10:0:C804:1AFF:FEAC:1C
    end
    version 15.0
    hostname R2
    ipv6 cef
    no ip address
    duplex auto
    speed auto
    ipv6 enable
    interface FastEthernet1/1
    no ip address
    duplex auto
    speed auto
    ipv6 address 2001:DB8:11::2/64
    ipv6 enable
    ipv6 dhcp relay destination 2001:DB8:10::1 FastEthernet1/0
    end
    version 15.0
    hostname R3/hostname R4
    ipv6 nd route-owner
    ipv6 cef
    no ip address
    duplex auto
    speed auto
    ipv6 address dhcp rapid-commit
    ipv6 enable
    end
    Note:
    • Static route to reach the clients (client prefix 2001:db8:11::/64) is added in the DHCPv6 Server so that it can reach clients
    • Under Client configuration
    The command ipv6 nd route-owner inserts Neighbor Discovery-learned routes into the routing table with "ND" status and enables ND autoconfiguration behavior.This command is configured in Global Configuration mode.
    Enabling the command ipv6 nd autoconfig prefix in the interface configuration mode, uses Neighbor Discovery to install all valid on-link prefixes from RAs received on the interface.
    To allow Neighbor Discovery to install a default route to the Neighbor Discovery-derived default router, use the command  ipv6 nd autoconfig default-route in the interface configuration mode
    Verify Commands
    show ipv6 route
    In client routers R3 and R4 default route is installed for the ND derived default router.Use this command show ipv6 route to check the routing table.
    R3#show ipv6 route
    IPv6 Routing Table - default - 5 entries
    Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
           B - BGP, HA - Home Agent, MR - Mobile Router, R - RIP
           I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary
           D - EIGRP, EX - EIGRP external, ND - Neighbor Discovery
           O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
           ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
    ND  ::/0 [2/0]
         via FE80::C804:1AFF:FEAC:1D, FastEthernet1/0
    ND  2001:DB8:11::/64 [2/0]
         via FastEthernet1/0, directly connected
    LC  2001:DB8:11:0:209E:3F6C:3900:7602/128 [0/0]
         via FastEthernet1/0, receive
    ND  2001:DB8:11:0:F145:5C6F:3658:7DB6/128 [2/0]
    L   FF00::/8 [0/0]
         via Null0, receive
    show ipv6 dhcp pool
    To display the DHCPv6 pool information, in the DHCPv6 server use this command. The output shows that the number of active clients is 2 and  also displays other configuration parameter information, such as domain  name server address and preferred life time information.
    R1#show ipv6 dhcp pool
    DHCPv6 pool: test
      Address allocation prefix: 2001:DB8:11::/64 valid 4294967295 preferred 4294967295 (2 in use, 0 conflicts)
      DNS server: AAAA:BBBB:FE10::100
      DNS server: 2001:DB8::5
      Domain name: example.com
      Active clients: 2
    show ipv6 dhcp binding
    To display the information information about the clients, which includes their DUIDs, IAPDs, prefixes, and preferred and valid lifetimes.
    R1#sh ipv6 dhcp bin
    Client: FE80::C805:FFF:FE84:1C
      DUID: 00030001CA050F840000
      Username : unassigned
      IA NA: IA ID 0x00040001, T1 43200, T2 69120
        Address: 2001:DB8:11:0:F145:5C6F:3658:7DB6
                preferred lifetime INFINITY, , valid lifetime INFINITY,
    Client: FE80::C806:FFF:FE84:1C
      DUID: 00030001CA060F840000
        Address: 2001:DB8:11:0:209E:3F6C:3900:7602
    show ipv6 dhcp interface
    This command shows that interface Fa1/1 is configured in Relay Mode and displays the relay destination to which  messages from clients should be forwarded.
    R2#show ipv6 dhcp interface
    FastEthernet1/1 is in relay mode
      Relay destinations:
        2001:DB8:10::1 via FastEthernet1/0
    The configuration on the client's side can be verified using the same command in router R3 and R4.
    R4#show ipv6 dhcp interface
    FastEthernet1/0 is in client mode
      Prefix State is IDLE
      Address State is OPEN
      Renew for address will be sent in 06:26:48
      List of known servers:
        Reachable via address: FE80::C804:1AFF:FEAC:1D
        DUID: 00030001CA031AAC0000
        Preference: 0
        Configuration parameters:
            Address: 2001:DB8:11:0:F145:5C6F:3658:7DB6/128
                    preferred lifetime INFINITY, valid lifetime INFINITY
          Information refresh time: 0
      Prefix Rapid-Commit: disabled
      Address Rapid-Commit: disabled
    R3#show ipv6 dhcp interface
      Renew for address will be sent in 06:11:30
        Preference: 0
            Address: 2001:DB8:11:0:209E:3F6C:3900:7602/128
      Address Rapid-Commit: enabled
    Ping
    You can check the connectivity between the DHCPv6 server and Clients using the ping command
    R1#ping 2001:DB8:11:0:209E:3F6C:3900:7602 (Pinging Client 1 R3 from DHCPv6 Server)
    Sending 5, 100-byte ICMP Echos to 2001:DB8:11:0:209E:3F6C:3900:7602, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 24/66/120 ms
    R1#ping 2001:DB8:11:0:F145:5C6F:3658:7DB6(Pinging Client 2 R4 from DHCPv6 Server)
    Sending 5, 100-byte ICMP Echos to 2001:DB8:11:0:F145:5C6F:3658:7DB6, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 0/113/400 ms
    Now ping the DHCPv6 server address from the clients R3 and R4.
    R3#ping 2001:db8:10::1 (DHCPv6 server Fa1/0 Interface IPv6 address)
    Sending 5, 100-byte ICMP Echos to 2001:DB8:10::1, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 8/48/168 ms
    R4#ping 2001:db8:10::1
    Success rate is 100 percent (5/5), round-trip min/avg/max = 8/80/140 ms
    References
    Routing Information Protocol
    jd219
    Beginner
    very good explanation.
