TCC_2
Level 10
Level 10
Core issue
The 1400 W DC multi-input supply cannot be used with other power supply types. However,  other power supplies in this product line work with the other types during an upgrade.
Resolution
If you mix power supplies in a Catalyst 4500 series chassis, the switch detects the type of power supply in power supply bay 1 (PS1) and ignores the power supply in power supply bay 2 (PS2) while issuing system messages and showing the power supply in bay 2 as in the err-disable state in the output of the show power command. When the power supply in bay 1 is removed, the switch recognizes the power supply in bay 2. You can then put a new matching power supply in bay 1. Both supplies should now resume normal function.
