The "%IMAGEMGR-6-AUTO_COPY_SW:" and "%IMAGEMGR-6-AUTO_ADVISE_SW:" error messages appear during the auto-upgrade on the 3750 stack
1726
Core issue
When the auto-upgrade process cannot find the appropriate stack member software to copy to the switch in voicemail (VM) mode, the auto-advise process tells you the command, which is the archive copy-sw or archive download-sw privileged EXEC command, and the image name (tar filename) needed in order to manually upgrade the switch stack or the switch in VM mode.
The recommended image can be the running switch stack image or a tar file in any flash file system in the switch stack, which includes the switch in VM mode. Auto-advise cannot be disabled, and there is no command to check its status.
The Unable to create temp dir "flash:update" error message appears because an update to the temp file is created when a failure is experienced.
Resolution
In order to resolve this issue, complete these steps:
  1. Use thermdir flash:update command in order to delete the temp file.
  2. Issue the deleteflash:update command.
  3. If the rmdir flash:update command does not work, then try the delete /force /recursive flash:update command and then continue with the upgrade.
Refer to the Understanding Auto-Upgrade and Auto-Advise section of Managing Switch Stacks for more information
Content for Community-Ad
