Core issue
This message indicates that the Supervisor Line-Card Processor (SLCP) failed to respond to requests from the Supervisor Engine's Network Management Processor (NMP). The [dec] portion of the error message is the module number. This problem is identified in Cisco bug ID CSCea38268.
As per the bug release notes, a Catalyst 6500 Series Switch with a Supervisor 1/1A or 2 may reload with this log message:
ProcessStatusPing:Module 1 local SCP error detected... resetting module
Resolution
No action is required unless the module fails again.
If the issue is not resolved, please contact Cisco Technical Support online using the TAC Service Request Tool.
