Troubleshooting high CPU on a 6500 with sup720
96450
The purpose of this document is to cover how to determine the cause of high CPU on a 6500/7600 with a sup720.  The troubleshooting methods discussed in this documentation will make it possible to determine the cause of 90% of all high CPU issues on the sup720.
The majority of high CPU on the sup720 is related to CPU usage on the MSFC, thus the majority of this document will cover high CPU on the MSFC.
Because it would not be possible to cover every possible reason high CPU can be caused on the sup720, I will demonstrate how to use some of the tools built-in to the sup720 to show general methods on how to narrow down the cause of high CPU.
If you are unable to determine the reason based on this documentation, please open a TAC case to investigate this issue further.
**Note that these methods can be used to determine the cause of high CPU on a RSP720, Sup32 and VS-S720, due to common architecture.
Determining Where the CPU utilization is occurring:
Within the sup720 6500, there are two types of CPU’s.   One is used for layer 2 operations and is commonly referred as the SP (Switch Processor) CPU.  The other CPU is used for layer3/4 operations and it commonly referred to as the RP(Route Processor) CPU.  Both of these processors are located on the MSFC3 complex, each with a 1 gig in-band channel to the supervisor.
Also depending on the module you may also have a DFC (Distributed Feature Card) to perform forwarding locally on that module.  The DFC also has its own CPU, which performs processing locally on the line card.  Under certain scenarios high CPU can be seen on these modules.
High CPU on the SP (Switch processor):
High CPU on the SP is much less common than high CPU on the RP.   The reasons for high CPU on the SP are typically related to layer 2 operations of the sup720, such a spanning-tree (processing of BPDU's) or processing IGMP snooping/IGMP queries/membership reports as well as LACP/PAGP.
You can view the CPU utilization using the following command:
SP CPU Util:
Switch# remote command switch show process cpu
OR
Switch#remove login switch
Switch-sp#show process cpu
High CPU on the RP (Route Processor):
This will be traffic that needs to be processed for layer 3 operations, such as ARP, HSRP, forwarding traffic in software.   Below I will go over troubleshooting steps when seeing high CPU on the IP Input/ARP input process as well as CPU utilization caused by interrupt switched traffic on the RP CPU.
RP CPU Util:
Switch#show process cpu
High CPU on a DFC/module:
The CPU on the DFC will help in programming TCAM and router in hardware, since each DFC has its own TCAM.
High CPU on a DFC is not very common and can occur for a few different reasons.  One reason you may see high CPU on the DFC is due to Netflow Data Export.   Typically CPU from NDE is expected, but in rare instances it can become high enough to disrupt other processes.
DFC CPU Util:
Switch# attach <module>
Switch-DFC#show process cpu
Types of CPU utilization:
There are two type of CPU utilization within IoS, interrupt and process.
Process based CPU utilization:
CPU utilization caused by a process can be caused by few reasons listed below:
1.) Processes switched traffic.  This is traffic that is hitting a specific process in order to be forwarded OR processed by the CPU.  An example of each would traffic being forwarded via the "IP Input" process OR control-plane traffic hitting the "PIM process".
2.) A process trying to clean up tables/previous actions performed.  This can be seen in process such a "CEF Scanner" OR "BGP Scanner", which are used to clean/update the CEF and BGP tables.
Interrupt based CPU utilization:
CPU caused by an interrupt is always traffic based.  Interrupt switched traffic, is traffic that does not match a specific process, but still needs to be forwarded.
Determining the type of CPU utilization:
Process and Interrupt CPU utilization are listed within the "show process cpu" command.   This is broken down below on how to determine what percentage of the CPU utilization is due to interrupt traffic or processed switched traffic:
6500-3#sh proc cpu
CPU utilization for five seconds: 0%/0%; one minute: 0%; five minutes: 0%
Red - Percentage of total CPU utilization
Blue - Percentage of the CPU that is caused by Interrupts.
Percentage of process CPU util. = Total CPU - Interrupt CPU util.
Common reasons for HIGH CPU on the MSFC/RP:
IP traffic with a TTL of 1 - Due to the fact we need to send an IP unreachable message to the host letting them know the message has expired in transit.  This cannot be done in hardware and thus the packet must be punted to the MSFC.  Find the device sending traffic the TTL of 1 and stop is from sending traffic, increase the TTL OR install the MLS TTL rate-limiter.
Using an ACL with the log keyword - Since a log keyword requires a syslog message to be generated this must be punted to the RP CPU as it cannot be done in hardware. Remove the log keyword from the ACL.
Using a PBR route-map without a set statement - Any traffic that matches a PBR route-map with no set statement will be punted.  This is due to the fact that we need to program the next-hop in hardware and if the next-hop is not known, this traffic must be punted to determine the next hop.  Configure a set statement OR remove the policy route from the interface.
FIB TCAM Exception - If you try to install more routes than are possible into the FIB TCAM  you will see the following error message in the logs:
CFIB-SP-STBY-7-CFIB_EXCEPTION : FIB TCAM exception, Some entries will be software switched
%CFIB-SP-7-CFIB_EXCEPTION : FIB TCAM exception, Some entries will be software switched
%CFIB-SP-STBY-7-CFIB_EXCEPTION : FIB TCAM exception, Some entries will be software switched
This error message is received when the amount of available space in the TCAM is exceeded. This results in high CPU. This is a FIB TCAM limitation. Once TCAM is full, a flag will be set and FIB TCAM exception is received. This stops from adding new routes to the TCAM. Therefore, everything will be software switched. The removal of routes does not help resume hardware switching. Once the TCAM enters the exception state, the system must be reloaded to get out of that state. You can view if you have hit a FIB TCAM exception with the following command:
6500-2#sh mls cef exception status
Current IPv4 FIB exception state = TRUE
Current IPv6 FIB exception state = FALSE
Current MPLS FIB exception state = FALSE
When the exception state is TRUE, the FIB TCAM has hit an exception.
The maximum routes that can be installed in TCAM is increased by the mls cef maximum-routes command.
This issue is common when trying to route a full BGP table on PFC-3A or a PFC-3B.
**Note a failover of the supervisors in dual supervisor system will not recover this exception, even through the “show mls cef exception status” will no longer indicate a FIB exception.  A full reload of the switch is required.
ICMP redirects - If traffic is taking a path that is not efficient, an ICMP redirect will be sent out to inform the host of a better next-hop.  This will cause the packet to be punted in order to trigger the MSFC to send the ICMP redirect to the host. This can be seen when performing a netdr capture.  An example of using netdr can be seen in the “Tools used to determine the source of the CPU utilization: section
Turn off icmp redirects to stop this traffic from being punted.  However this is an indication of network inefficiency that was attempting to be dynamically resolved.   User interaction is needed in order to track down this inefficiency.
If you need assistance in determining why ICMP redirects are being generated please open a TAC case
CEF Glean adjacency  - This can happen when no ARP resolution for the next hop.  All traffic must be punted in order to trigger an ARP request for the next hop.  This will always manifest it self as interrupt based traffic.
To protect the RP CPU from this issue you can implement the Glean adj. mls rate-limiter.
Netflow and ACL feature configured on the same interface matching the same traffic - You cannot have an ACL based feature and a Flow based feature configured on the same interface for the same traffic.  An Example of this would be having NAT and PBR configured on the same interface matching the same traffic.
NAT is netflow assisted, as the first packet in every flow would need to be punted to create the netflow entry in hardware.  Once the netflow entry is created all subsequent packets will hit this hardware netflow entry and thus be forwarded in hardware.
Policy-Based Routing is ACL based. This will create a “policy-route” state
when a route-map is configured to use PBR and applied to that interface.   This will point to a special adjacency, which is where the next-hop is specified in the “set” statement of the route-map.
The issue comes when a packet matches both the NAT and the PBR feature, the traffic can not be sent to the CPU to be put into Netflow AND be redirected to the PBR special adj, thus this traffic must be software switched.  If these two features overlap, these features are taken out of hardware and the traffic is software switched.  When this occurs neither feature may be applied to the matching traffic.
If a packet does not match both the ACL based feature and Netflow based feature match criteria then the relevant function (ACL based or Netflow based) will be performed in hardware.
Therefore, for proper hardware based performance in situations where ACL based features and Netflow based features are configured on the same interfaces it is important to have unique policies.
To work around this problem do not have both an ACL based and Netflow based feature configured on the same interface, matching the same traffic.
You can read more about troubleshooting feature conflict issues via the following link:
https://supportforums.cisco.com/docs/DOC-15670
Directed Broadcast traffic – All broadcast traffic must be sent to the MSFC on a vlan when a layer 3 interface is configured within that vlan.  This includes directed broadcast traffic.   Use multicast instead of directed broadcast.
Bridging loop - If a bridging loop occurs on the network, this could cause high CPU on the MSFC. All broadcast traffic must be sent to the MSFC on a vlan when a layer 3 interface is configured within that vlan.
You can determine what traffic is hitting the CPU by using a netdr capture to track down the source interface of the loop (See Using Netdr to determine traffic punted to the CPU section).
GRE with non-unique  tunnel source - On the sup720, tunnel sources must be unique for all tunnels. Tunnels with a non-unique source will be software switched. The workaround for this limitation is to use either unique loopback interfaces for every GRE tunnel OR  use secondary addresses on a loopback interface for the tunnel source addresses.       For more information see CSCdy72539.
You may also see the following error:
%Warning: Using same source IP for more than one IP/GRE tunnels may cause software switching packets for tunnels using this address. If possible, use a unique tunnel source for Interface Tunnel <tun#>
Other common unsupported features on Sup720-PFC3:
The following features/traffic types are common features that are not supported by the 6500 and will cause high CPU if implemented:
**Note this is not an exhausted list and there may be unsupported features not listed below.
NBAR
Traffic with IP options field set.
Multicast RPF drops
RSVP (INTSERV QOS) *can be used for tunnels
CEF accounting
Multicast traffic and NAT – see CSCek78254
The following link will give a larger list of all unsupported features and commands on the sup720-PFC3:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/features.html#wp3691673
Determine the source of RP CPU utilization using interface buffers:
**Note** you will only be able to see traffic in the interface buffers on a layer 3 interface if the traffic is being processed switched (see “Determining type of CPU utilization” above).  This will not work when traffic is being interrupt switched.  In the case of interrupt switched traffic use the netdr capture instead.
One of the quickest ways to determine the layer 3 interface that is the source of traffic that is causing high CPU is to see which interface has a large amount of drops flushes on the interfaces input queue.  The input queue on a layer 3 interface is the CPU queue for that interface on the sup720.   If we ever see packets/drops on the input queue on the sup720 it is always due to traffic that is being sent towards the CPU.  You can narrow down the location of such an interface with the following commands:
6500-2#show interface | include  is up|drop
Vlan10 is up, line protocol is up
  Input queue: 74/75/18063/18063 (size/max/drops/flushes); Total output drops: 0
Vlan20 is up, line protocol is up
We can see that SVI (Switched Virtual Interface) 10 has 74 packets in its buffer, whose queue size is 75 packets. This demonstrates that a large amount of traffic is being punted on this interface to the RP CPU, since this queue is full.
Now that we can see a large amount of traffic within this queue, we can look at what is in this queue with the command "show buffers input-interface vlan 10 header".  This command will display the IP header of the packet so we can attempt to determine the source.  If you want to look at the entire packet you can use the command  "show buffers input-interface vlan 10 packet".
Below is the output from this command for SVI 10
6500-2#sh buffers input-interface vlan 10 header
Buffer information for Small buffer at 0x4667A08C
  data_area 0x802F664, refcount 1, next 0x466AE968, flags 0x200
  linktype 7 (IP), enctype 1 (ARPA), encsize 14, rxtype 1
  if_input 0x530D5048 (Vlan10), if_output 0x0 (None)
  inputtime 00:00:00.000 (elapsed never)
  outputtime 00:00:00.000 (elapsed never), oqnumber 65535
  datagramstart 0x802F6DA, datagramsize 60, maximum size 308
  mac_start 0x802F6DA, addr_start 0x802F6DA, info_start 0x0
  network_start 0x802F6E8, transport_start 0x802F6FC, caller_pc 0x41F78790
  source: 10.10.10.2, destination: 10.100.101.10, id: 0x0000, ttl: 1,
  TOS: 0 prot: 6, source port 0, destination port 0
Above we can see the basic information about this traffic that is included in the IP header, including the TOS, TTL and protocol encapsulated within the IP header.
If we viewed the entire packet we can look at more in depth information including the layer 2 information, as can be seen below:
6500-2#sh buffers input-interface vlan 10 packet
Buffer information for Small buffer at 0x466A23B0
  data_area 0x80340A4, refcount 1, next 0x466E991C, flags 0x200
  if_input 0x52836BE4 (Vlan10), if_output 0x0 (None)
   inputtime 16:32:10.292 (elapsed 00:00:50.608)
  datagramstart 0x803411A, datagramsize 60, maximum size 308
  mac_start 0x803411A, addr_start 0x803411A, info_start 0x0
  network_start 0x8034128, transport_start 0x0, caller_pc 0x41F78790
       0: 0015C726 FB800000 01000600 08004500  ..G&{.........E.
      16: 002E0000 00000106 36510A0A 0A020A64  ........6Q.....d
      32: 650A0000 00000000 00000000 00005000  e.............P.
      48: 0000265C 00000001 02030405 FD        ..&\........}
Red = Dest MAC
Blue = Source MAC
Green = Ethertype (0x800 for IP traffic)
Purple = Src. IP
Orange = Dest IP
Using “show ip traffic” statistics to see why traffic is punted:
6500-2#show interface | i is up|drop
SVI 10/Interface Vlan 10 is receiving a large amount of traffic that is being punted to the RP CPU.  When we look at what is in this queue with the command "show buffers input-interface vlan 10 header".
Buffer information for Small buffer at 0x4667C7E8
  data_area 0x80314A4, refcount 1, next 0x46695FD0, flags 0x200
  datagramstart 0x803151A, datagramsize 60, maximum size 308
  mac_start 0x803151A, addr_start 0x803151A, info_start 0x0
  network_start 0x8031528, transport_start 0x803153C, caller_pc 0x41F78790
  source: 10.10.10.1, destination: 10.10.10.2, id: 0xD096, ttl: 255, prot: 1
Since at this point we are unsure why this traffic is being punted, we can look at “show ip traffic" statistics to see why this traffic is being punted to the CPU.  First start by clearing the IP traffic statistics.  We can then see what is incrementing in these counters to see what would be the cause:
6500-2#clear ip traffic
Clear "show ip traffic" counters [confirm]
6500-2#sh ip traffic
IP statistics:
  Rcvd:  33516 total, 0 local destination
         0 format errors, 0 checksum errors, 33516 bad hop count <------We can see that the bad Hop count in this case is incrementing
         0 unknown protocol, 0 not a gateway
         0 security failures, 0 bad options, 0 with options
  Opts:  0 end, 0 nop, 0 basic security, 0 loose source route
         0 timestamp, 0 extended security, 0 record route
         0 stream ID, 0 strict source route, 0 alert, 0 cipso, 0 ump
         0 other
  Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
         0 fragmented, 0 couldn't fragment
  Bcast: 0 received, 0 sent
  Mcast: 0 received, 0 sent
  Sent:  0 generated, 0 forwarded
  Drop:  40005 encapsulation failed, 0 unresolved, 0 no adjacency
         0 no route, 0 unicast RPF, 0 forced drop
         0 options denied, 0 source IP address zero
ICMP statistics:
  Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 0 unreachable
        0 echo, 0 echo reply, 0 mask requests, 0 mask replies, 0 quench
        0 parameter, 0 timestamp, 0 info request, 0 other
        0 irdp solicitations, 0 irdp advertisements
        0 time exceeded, 0 timestamp replies, 0 info replies
  Sent: 0 redirects, 0 unreachable, 0 echo, 0 echo reply
        0 mask requests, 0 mask replies, 0 quench, 0 timestamp
        0 info reply, 58464 time exceeded, 0 parameter problem   <---- We can also the 6500 is sending ICMP TTL expired messages as well.
<snip>
Looking at the traffic statistics we can see that the bad hop count counter is incrementing and the switch is sending ICMP time exceeded messages.
On the 6500 all traffic with a TTL of 1 is punted to the CPU so that an ICMP TTL expired message can be sent to the host who sent this traffic.
Also, the first packet in the buffer can be seen to have TTL of 1, which is why this traffic is punted.  We can see that the 2nd packet is sourced from 10.10.10.1 (SVI 10) sent to 10.10.10.2. This packet is an ICMP TTL expired message.
Using Netdr to determine traffic punted to the CPU:
A netdr capture is preformed on the MSFC CPU controller.  This is the closest location you can capture a packet on the MSFC in order to determine why traffic is being punted to the MSFC/RP CPU.  With a Sup720 or Sup32 it allows one to capture packets on the RP or SP inband. The netdr command can be used to capture both Tx and Rx packets in the software-switching path.
Cat6500#debug netdr capture ?
acl                     (11) Capture packets matching an acl
and-filter              (3) Apply filters in an and function: all must match
continuous              (1) Capture packets continuously: cyclic overwrite
destination-ip-address  (10) Capture all packets matching ip dst address
dstindex                (7) Capture all packets matching destination index
ethertype               (8) Capture all packets matching ethertype
interface               (4) Capture packets related to this interface
or-filter               (3) Apply filters in an or function: only one must match
rx                      (2) Capture incoming packets only
source-ip-address       (9) Capture all packets matching ip src address
srcindex                (6) Capture all packets matching source index
tx                      (2) Capture outgoing packets only
vlan                    (5) Capture packets matching this vlan number
<cr>
OPTIONS:
  • Using the continuous option, the switch will capture packets on the RP-inband continuously fill the entire capture buffer (4096 packets) and then start to overwrite the buffer in a FIFO fashion.
  • The tx and rx options will capture packets coming from the MSFC and going to the MSFC respectivey.
  • The and-filter and the or-filter specify that an and or an or will be applied respectively to all of the options that follow. For example, if you use the syntax below, then both option #1 and option #2 must match for the packet to be captured. Similarly, if the or-filter is used either option #1 or option #2 or both must match for the packet to be captuered.
    • debug netdr and-filter option#1 option#2
  • The interface option is used to capture packets to or from the specified interface. The interface can be either an SVI or a L3 interface on the switch.
  • The vlan option is used to capture all packets in the specified VLAN. The VLAN specified can also be one of the internal VLANs associated with a L3 interface.
  • The srcindex and dstindex options are used to capture all packets matching the source ltl and destination ltl indices respectively. Note that the interface option above only allows the capture of packets to or from a L3 interface (SVI or physical). Using the srcindex or dstindex options allows the capture of Tx or Rx packets on a given L2 interface. The srcindex and dstindex options work with either L2 or L3 interface indices.
  • The ethertype option allows the capture of all packets matching the specified ethertype.
  • The source-ip-address and destination-ip-address options allow the capture of all packets matching the specified source or destination IP address respectively.
Below is an example of capturing traffic destined to 10.100.101.10 sourced from 10.10.10.2 going to the RP CPU:
6500-2#debug netdr cap rx and-filter source-ip-address 10.10.10.2 destination-ip-address 10.100.101.10
6500-2#sh netdr cap
A total of 4096 packets have been captured
The capture buffer wrapped 0 times
Total capture capacity: 4096 packets
------- dump of incoming inband packet -------
interface Vl10, routine mistral_process_rx_packet_inlin, timestamp 00:00:11
dbus info: src_vlan 0xA(10), src_indx 0xC0(192), len 0x40(64)
bpdu 0, index_dir 0, flood 0, dont_lrn 0, dest_indx 0x380(896)
10020400 000A0000 00C00000 40080000 00060468 0E000040 00000000 03800000
mistral hdr: req_token 0x0(0), src_index 0xC0(192), rx_offset 0x76(118)
  requeue 0, obl_pkt 0, vlan 0xA(10)
destmac 00.15.C7.26.FB.80, srcmac 00.00.01.00.06.00, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 46, identifier 0
  df 0, mf 0, fo 0, ttl 100, src 10.10.10.2, dst 10.100.101.10
tcp src 0, dst 0, seq 0, ack 0, win 0 off 5 checksum 0x265C
Red = Ingress Vlan of traffic
Blue = Layer 3 interface traffic is coming from
Green = Ethertype and SRC/DST MAC addresses
Purple = IP Header
Orange = SRC index (source of ingress traffic).
Dark Red = Dest Index (where traffic is being sent).
You can use this information to track down the source of the traffic being punted.  Please refer to Troubleshooting with a NETDR capture on a sup720/6500 documention for a further explanation of how to interpret this data.
Please open a TAC case if you need further assistance interpreting this data.
Using a CPU SPAN to determine traffic being punted to the CPU
This capture is performed on the ASIC, which is connected to the RP/SP CPU.    This will allow you to replicate traffic that is being sent to the RP or SP CPU to a capture device.   This can be handy for determine the cause of the HIGH CPU OR determining if traffic is being sent to or from the CPU for processing (such as HSRP/OSPF/PIM control plane traffic).
When using the 12.2(18)SXF train and earlier the  configuration for an inband span session is as follows:
RP Console:
Router#monitor session <1-66> <source|destination|filter> <interface|remote|vlan> <FastEthernet|GigabitEthernet|Port-channel|GE-WAN> <tx|rx|both>
SP Console:
Router#remote login switch
Router-sp#test monitor session <1-66> <add|del|show> <rp-inband|sp-inband> <tx|rx|both>
-OR-
Router-sp#test monitor <add|del|> <session: 1-66> <rp-inband|sp-inband> <tx|rx|both>
Router-sp#test monitor session <1-66> <show>
On the 12.2(33)SXH train and later, this is the configuration for an inband sp->rp span session:
Router(config)# monitor session 1 type local
Router(config-mon-local)# source cpu  <rp|sp> <tx|rx|both>
Router(config-mon-local)# destination interface gigabitethernet 1/2
Router(config-mon-local)# no shutdown
For more information please reference the following link:
http://cco.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/span.html#wp1109488
Once this information is collected you can then use the source MAC/source IP information to determine the source of the traffic.
Troubleshooting CPU spikes.
At times it is not possible to determine the cause of a CPU spike, since a "show process CPU" cannot be run during the times of the issue.  One way to get around this would be to setup an EEM script to run the command for you when the CPU goes above a certain value.   The following EEM script will run a "show process cpu sorted" when the CPU utilization of the device goes above 50%:
event manager scheduler script thread class default number 1
event manager applet High_CPU
event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.3.1 get-type exact entry-op ge entry-val 50 poll-interval 0.5
  action 0.0 syslog msg "High CPU DETECTED. Please wait - logging Information to <file system>:high_cpu.txt"
  action 0.1 cli command "enable"
  action 0.2 cli command "show clock | append <file system>:high_cpu.txt"
  action 1.2 cli command "term length 0"
  action 1.3 cli command "show process cpu sorted | append <file system>:high_cpu.txt"
Please fill in <file system> with the location of the file system without "<" or ">".
If you need further assistance in determining the cause of your high CPU please open a Cisco TAC case.
Nice and informative.
You might wanna check the SNMP OID though.. Looks like there is a typo.
1.3.6.1.4.1.9.9.109.1.1.1.1.3 is a valid OID ( Ends with 3 not 3.1 )
Cheers,
Akshay
Beginner
Under section "common reasons for High CPU on MSFC/RP:"
How about a situation where PBR route-map is used with a match ip access-list and set statement, but the ip access-list does not exist on the router ?
Beginner
Akshay,
look at this nice document about CPU monitoring and OIDs
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094a94.shtml
Petr
Beginner
Hi Akshay,
Some document end with 3.1. Please advise
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/63992-6k-high-cpu.html
Enthusiast
Great article!
Thanks for sharing
Content for Community-Ad
