Troubleshooting OTV Adjacency
467
OTV adjacency is formed across the layer 3 multicast clouds by exchanging L1 ISIS Hello packets.
Sample Topology
1. Verify IGMP V3 Join
After the OTV configuration completed, enabling the join interface sends any source IGMP v3 join on that interface.
SITE1-OED1# show run int eth 1/31
interface Ethernet1/31
  description [OTV-JOIN-INTERFACE]
  vrf member OTV
  ip address 10.10.15.6/30
  ip router eigrp 10
  ip igmp version 3
SITE1-OED1(config-if)# int eth 1/31
SITE1-OED1(config-if)# no shut
SITE1-AGG1%OTV# show ip mroute
IP Multicast Routing Table for VRF "OTV"
(*, 239.1.1.1/32), uptime: 0.283775, igmp pim
  Incoming interface: Ethernet1/5, RPF nbr: 10.10.15.1      <<< Interface facing Multicast RP
  Outgoing interface list: (count: 1)
    Ethernet1/9, uptime: 0.283711, igmp          <<< Interface connecting to OTV VDC SITE1-OED1
2. Verify ISIS Hello Packets
When you enable the OTV overlay interface, the switch will generate a L1 ISIS hello packet with the source IP address as the OTV join interface and the destination IP address as the OTV control-group.
(*, 239.1.1.1/32), uptime: 00:16:00, igmp pim ip
    Ethernet1/9, uptime: 00:16:00, igmp
(10.10.15.6/32, 239.1.1.1/32), uptime: 00:00:19, ip mrib pim  <<< S,G entry represents Mcast packet received from 10.10.15.6
  Incoming interface: Ethernet1/9, RPF nbr: 10.10.15.6
    Ethernet1/9, uptime: 00:00:19, mrib, (RPF)
3. Verify Multicast Transport
After all the four OTV edge devices are configured and enabled, the multicast transport network should show all the sources
(*, 239.1.1.1/32), uptime: 00:23:13, igmp pim ip
    Ethernet1/9, uptime: 00:23:13, igmp
(10.10.15.6/32, 239.1.1.1/32), uptime: 00:07:33, ip mrib pim       <<< SITE1-OED1
  Outgoing interface list: (count: 2)
    Ethernet1/5, uptime: 00:05:44, pim
    Ethernet1/9, uptime: 00:07:33, mrib, (RPF)
(10.10.16.6/32, 239.1.1.1/32), uptime: 00:04:48, ip mrib pim      <<< SITE1-OED2
    Ethernet1/9, uptime: 00:04:48, mrib
(10.10.17.6/32, 239.1.1.1/32), uptime: 00:04:21, ip mrib pim      <<< SITE2-OED1
    Ethernet1/9, uptime: 00:04:21, mrib
(10.10.18.6/32, 239.1.1.1/32), uptime: 00:03:46, ip mrib pim       <<< SITE2-OED2
    Ethernet1/9, uptime: 00:03:46, mrib
You can also monitor the OTV control packets statistics as below.
SITE1-AGG1%OTV# show ip mroute summary
Total number of routes: 6
Total number of (*,G) routes: 1
Total number of (S,G) routes: 4
Total number of (*,G-prefix) routes: 1
Group count: 1, rough average sources per group: 4.0
Group: 232.0.0.0/8, Source count: 0
Source          packets      bytes           aps   pps       bit-rate     oifs
(*,G)           0            0               0     0         0.000   bps  0
Group: 239.1.1.1/32, Source count: 4
(*,G)           7            10106           1443  0         0.000   bps  1
10.10.15.6      73           86674           1187  0         1349.600 bps 2
10.10.16.6      96           76987           801   0         1429.600 bps 1
10.10.17.6      103          81610           792   0         1416.267 bps 1
10.10.18.6     155          144435          931   0         4092.800 bps 1
4. Verify OTV ISIS Adjacency
You can verify the Adjacency using the below command:
SITE1-OED1# show otv adjacency detail
Overlay Adjacency database
Overlay-Interface Overlay1  :
Hostname                         System-ID      Dest Addr       Up Time   State
SITE1-OED2                       0024.986f.bac4 10.10.16.6      00:05:31  UP
HW-St: Up Peer-ID: 3
SITE2-OED1                       0026.51ce.0f43 10.10.17.6      00:46:29  UP
HW-St: Up Peer-ID: 2
SITE2-OED2                       0026.51ce.0f44 10.10.18.6      00:46:29  UP
HW-St: Up Peer-ID: 1
5. Troubleshoot OTV ISIS Adjacency
If there is any issue in establishing OTV ISIS adjacency, you can look at the ISIS adjacency log as below:
SITE1-OED1#  show otv isis internal event-history adjacency
ISIS default process
adjacency Events for ISIS process
2011 May 21 08:54:53.773678 isis_otv default [10371]: (Overlay1) : LAN adj L1
SITE2-OED1 over Overlay1 - UP
2011 May 21 08:54:53.773662 isis_otv default [10371]: [10376]: Sent OTV add adja
cency for overlay:Overlay1, addr: 10.10.17.6
2011 May 21 08:54:53.653906 isis_otv default [10371]: (Overlay1) : Set adjacency
SITE2-OED1 over Overlay1 IPv4 address to 10.10.17.6
2011 May 21 08:54:53.653827 isis_otv default [10371]: (Overlay1) : LAN adj L1
SITE2-OED1 over Overlay1 - INIT (New)
2011 May 21 08:54:53.653799 isis_otv default [10371]: [10376]: Initialize adj fo
r L1 MT-0 for iib Overlay1
You can clear the log as below:
SITE1-OED1# clear otv isis event-history
6. Verify OTV overlay interface
Verify Overlay interface is up.
OTV Overlay Information
Overlay interface Overlay1
VPN name            : Overlay1
VPN state           : UP
Extended vlans      : 100-200 (Total:101)
Control group       : 239.1.1.1
Data group range(s) : 232.1.1.0/26
Join interface(s)   : Eth1/31 (10.10.15.6)
Site vlan           : 95 (up)                <<< Site VLAN should be Up
Site VLAN should be in spanning tree forwarding on atleast one port in the OTV VDC. If not, the data will not be forwarded across the OTV even though the OTV overlay is up and adjacency is forwarded with other peers.
7. Verify Tunnel Creation
After the OTV adjacency is setup, OTV process creates implicit tunnels for each discovered peer. These tunnels will be used to forward the data across OTV to the respective site.
show otv internal event-history debug
2011 May 21 10:10:58.428388 otv [10358]: [10361]: otv_tunnel_gre_add Tunnel (10.
10.15.6, 10.10.17.6) does not exist, creating NEW
2011 May 21 10:10:58.426206 otv [10358]: [10361]: Received ISIS add adjacency me
ssage for (Overlay1, 10.10.17.6) , sid 0026.51ce.0f43
Tunnel process in the NX-OS creates these tunnels based on the request from OTV process. You can verify the implicit tunnels as below:
SITE1-OED1# show tunnel internal implicit otv brief
Interface                Status     IP Address        Encap type       MTU
Tunnel16424              up         --                GRE/IP           9178
Tunnel16425              up         --                GRE/IP           9178
SITE1-OED1# show tunnel internal implicit otv detail
Tunnel16424 is up
    MTU 9178 bytes, BW 9 Kbit
    Transport protocol is in VRF "OTV"
    Tunnel protocol/transport GRE/IP
    Tunnel source 10.10.15.6, destination 10.10.18.6
    Tx
    0 packets output, 1 minute output rate 0 packets/sec
    Rx
    0 packets input, 1 minute input rate 0 packets/sec
Tunnel16425 is up
    Tunnel source 10.10.15.6, destination 10.10.17.6
    Tx
    Rx
The below command will shows the mapping between OTV adjacency and implicit tunnel.
SITE1-OED1# show otv internal adjacency
System-ID        Dest Addr        Adj-State TM_State  Up Time   Adj-State inAS
0024.986f.bac4   10.10.16.6       default   default   00:05:59  UP        UP
HW-St: Up  Curr-Peer-St: Up,  New-Peer_St: Default Peer-ID: 3 N Tunnel16426
0026.51ce.0f43   10.10.17.6       default   default   00:46:57  UP        UP
HW-St: Up  Curr-Peer-St: Up,  New-Peer_St: Default Peer-ID: 2 N Tunnel16425
0026.51ce.0f44   10.10.18.6       default   default   00:46:58  UP        UP
HW-St: Up  Curr-Peer-St: Up,  New-Peer_St: Default Peer-ID: 1 N Tunnel16424
SITE1-OED1#
Content for Community-Ad
July's Community Spotlight Awards
