Unable to supply inline power to IP phones when hard-coding the ports to 100Mbps/Full in a Cisco Catalyst Switch with Power over Ethernet (PoE)
894
Core issue
Whenever the ports are configured for 100Mbps/Full-duplex, the IP phone does not power up. However, when the port is set to auto/auto it does power up.
Resolution
This is not an IOS  bug or IOS defect. It is by design.
Hence, in order to power up PoE devices (including access points), speed and duplex settings on the switch need to be set to auto/auto mode.
