Core issue
This message indicates that the CPU is near the operating temperature threshold limit. [dec] is the CPU number.
Resolution
Make sure there is adequate cooling in the chassis and that the chassis vents are clear. Also check if the fan tray is working properly.
To display environmental, temperature, and inline power status information, issue the show environment command.
