Chieh Yu
Cable Technology
Using UBR10K as Packet-Shelf and RFGW-10 as EQAM in MCMTS Setup
LAB GUIDE
TAC Carrier Services
Jack Yu 3/6/2009
Objective:
1.     Bring Narrowband Modems online off Modular Interfaces
2.     Bring Wideband Modems w-online with channel-bonding
Components:
                RFGW-10
                ESR-PRE2
                UBR10-MC5X20H (or U,S Cards)
                Generic DTI Server
                UBR10-2XDS-SIP
                SPA-24XDS-SFP (24 Port Modena SPA)
                CMTS IOS 12.3(23) BC or 12.2(33)SCB
Overview:
                This lab guide is intended for quick setup of a simple Lab deployment of MCMTS - with the UBR10K acting as the packet shelf and the RFGW10 as the EQAM.
Tasks:
1.     Topology Design Planning and Cabling
2.     DTI Clocking
3.     Modular-Cable Controllers
4.     MC5X20 Cable Interface Configuration
5.     Cable Bundle Interface Configuration
6.     Modular-Cable Interface Configurations
7.     RFGW-10 Configurations
8.     Wideband Channel Bonding Modems
For our design – we will utilize a total of 6 RF-channels.
We plan on using one primary channel directly off the 5x20 card, the remaining four channels at layer one will be off the Modena SPA. The remaining 4 channels will be one dedicated primary, a second shared primary and bonding channels, and remaining four RFs will be split into two bonding groups
5X20 Primary 609 Mhz – Primary
RF-Channel 0 615 Mhz – Remote Primary only
RF-Channel 1 621 Mhz – Remote Primary and Bonding channel 1
RF-Channel 2 627 Mhz – Bonding channel 1
RF-Channel 3 633 Mhz – Bonding channel 2
RF-Channel 4 639 Mhz – Bonding channel 2
I will use all 4 Upstreams of the 5X20 card in our setup.
To keep things simple, all DS/US listed here serve the same batch of modems on the same node – In actual deployment scenarios, this may not be the case as providers usually segment off certain rf-channels to certain nodes. Later on, the Cable Fiber Node allows us to define physical topology (only required for wideband bonding groups).
-       All of my 5 modems can reach and lock any of these 5 DS channels
-       All of my 5 modems can reach and lock any of these 4 US channels
Physical Cabling
- UBR SPA-24XDS-SFP Connects by two redundant GigE MM Fibers to RFGW-10 Gig3/13 and Gig3/14
- DTCC Ethernet connection to DTI server
- 5X20 in slot 6/1 domain 6/1/0 US0-4 Connects to Diplexer which leads to node
- RFGW-10 DS ports and 5x20 DS ports are combined and connect to the Diplexer which connects to the node.
RFGW10 Cabling:
The RFGW10 mapping of Qams to ports should be pointed out. The RF Gateway 10 has slots in the front for 10 DS-48 cards stacked vertically. They are numbered from slot 3 to 12, left to right. In the back there are 12 RF Slots stacked horizontally numbered  RF Slot 1 to 12 (1 on top, 12 on bottom).
The DS-48 in slot 3 translates to the first (rightmost) port on each of the 12 RF slots in the back. The DS-48 in slot 4 translates to the 2nd port on each of the 12 RF Slots in the back, etc etc.
Here’s the mapping:
Qam3/1 -> 1st RF Slot, 1st port – This is the top right most port in the back.
Qam3/2 -> 2nd RF Slot, 1st port – This is the 2nd from the top card, right most port
Qam3/3 -> 3rd RF Slot, 1st port – This is the 3rd from the top card, right most port
Qam4/1 -> 1st RF Slot, 2nd port – This is the topmost card, 2nd from the right port
Qam4/2 -> 2nd RF Slot, 2nd port – This is the 2nd from the top card, 2nd from the right port
Qam4/3 -> 3rd RF Slot, 2nd port – This is the 3rd from the top card, 2nd from the right port
In our example I am going to use RFGW10’s Interface Qam3/1 and Qam4/1 to simplify cabling (I only have one UCH2). I’ll combine the two RF Outputs from the rightmost 2 ports of the top RF Slot in the back with the RF outputs from the 5x20 slot 6/1 downstream into a DS combiner.
At that point I take the output of the combiner into the diplexer. All the 4 US ports will be combined in into the diplexer like a normal setup.
2.     Configuring the DTI Clock
Since we are running a modem off a primary going through a device other than the 5X20 – We’ll need some way to sync up the MAP grants and other DOCSIS timing related functions.
- MCMTS has many modular parts - The EQAM (RFGW10), The Packet-Shelf (UBR10K), etc
- We must be able to syncronize all these devices
- DTI server is the way
UBR10K-D3(config)#cable clock dti
*Jan 31 22:08:14.543: %IPCOIR-5-CARD_DETECTED: Card type 2cable-dtcc (0x5B0) in slot 2/1
*Jan 31 22:08:14.543: %IPCOIR-5-CARD_LOADING: Loading card in slot 2/1
*Jan 31 22:08:14.891: %SYS-5-CONFIG_I: Configured from console by vty0 (171.69.85.25)
*Jan 31 22:08:15.755: %C10K-5-LC_NOTICE: Slot[2/1] Line-card Image Downloaded...Booting...
*Jan 31 22:08:33.567: %IPCOIR-5-CARD_DETECTED: Card type 2cable-dtcc (0x5B0) in slot 2/1
*Jan 31 22:08:33.643: %UBR10KTCC-4-CHG_CLK_REF: Clock reference source set to DTI for DTCC card 2/1
*Jan 31 22:08:33.943: %UBR10K_ALARM-6-INFO: CLEAR CRITICAL slot 2/1/0 Active Card Removed OIR Alarm - subslot 1
*Jan 31 22:08:33.943: %IPCOIR-2-CARD_UP_DOWN: Card in slot 2/1 is up.  Notifying 2cable-dtcc driver.
*Jan 31 22:08:33.947: %UBR10KTCC-2-ACTIVE_TCC: DTCC card 2/1 is active with DTI as clock reference
*Jan 31 22:08:33.947: %UBR10KTCC-4-CHG_CLK_REF: Clock reference source set to DTI for DTCC card 2/1
SLOT 6/1: Jan 31 22:08:33.871: %CLCJIB-6-TSLOAD: JIB 0 timestamp is reloaded
SLOT 6/1: Jan 31 22:08:33.851: %CLCJIB-6-TSLOAD: JIB 0 timestamp is reloaded
*Jan 31 22:08:35.091: %UBR10KTCC-1-DTIPORTSERVER: DTCC slot 2/1 port 1 DTI server status changed to freerun, external clock source: none
UBR10K-D3#sh cable clock
Number of TCC Cards in the Chassis: 1
Active TCC Card is in slot: 2 subslot: 1,(DTCC Eightbells card)
Clock reference used by the active card is DTI
Active TCC card in slot 2/1
No card in slot 1/1
TCC Card 2/1 DTI status:
    Active Client port             : 1
    Active Client status           : normal
    Active Client Server status    : freerun
    Active Client frame error rate : < 2%
    Active Client CRC error count  : 0x02
    Standby Client Signal detected : yes
3.     Define the Modular-Cable Controllers:
Define your modular-cable controllers:
- These are the RF-Channels you will be using for your MCMTS setup
- Define the frequency/annex/mod/interleave you want - and mirror the configuration on the EQAM
- I suggest all frequencies you wish to bond be no more than 50Mhz apart maximum
Once you define the RF-Channels, the CMTS will know how to encapsulate the MPEG/DOCSIS frames into the L2TPv3 Frames which it will send out the SPA's Ethernet Interface. This packet will contain the proper DST/SRC IP and the DST/SRC MAC to the Eqam. The EQAM will look at the Depi ID and have a mapping to convert the incoming frames to the appropriate DOCSIS frame and send it on the appropriate Frequency/mod/interleave etc.
Why define frequency in Modular-Controller when the EQAM simply maps DEPI to the Frequency you choose on the EQAM?
Because Modem will compare the MDD message and realize the MDD describes on frequency but its receiving on another
Configuration:
- Define the SPA IP Address
- Define the Modular-host (Since SIP/SPA doesn't have enough horsepower CPU to encapsulate Docsis, use the 5X20's CPU listed here)
For each RF Channel you must define
- Define the RF-Channel's Downstream Channel-id
- Define the RF-Channel's Frequency, Annex, Modulation, and Interleave
- Define the IP address of the EQAM and Dst Mac Address and DEPI ID
- (Optional) Define the Network-delay – No longer recommended – there is a 550 usec delay already built in
In Example:
The EQAM'S ethernet mac address is 0022.9084.073f and is at 11.30.4.2. In RFGW10’s case the MAC address should be the mac address of any of the Interface Gigabits. For this example I used the Interface Gig1/3 on my RFGW10.
I am going to be encapsulating my stream with a Remote-ID of 4001. This will be important later on when we configure the EQAM side.
rf-channel 0 cable downstream channel-id 24
rf-channel 0 frequency 615000000 annex B modulation 256qam interleave 32
rf-channel 0 ip-address 11.30.4.2 mac-address 0022.9084.073f depi-remote-id 4000
Here you can see I've defined 615Mhz though 639 Mhz for the 5 Channels we’ll be using.
controller Modular-Cable 1/0/0
ip-address 11.30.4.1                    ! This is the Modena’s IP address – Used in the SRC IP of the header
modular-host subslot 6/1             ! This defines the 5x20 card whose CPU will be used to generate the DOCSIS Frames
rf-channel 1 cable downstream channel-id 25
rf-channel 1 frequency 621000000 annex B modulation 256qam interleave 32
rf-channel 1 ip-address 11.30.4.2 mac-address 0022.9084.073f depi-remote-id 4001
rf-channel 2 cable downstream channel-id 26
rf-channel 2 frequency 627000000 annex B modulation 256qam interleave 32
rf-channel 2 ip-address 11.30.4.2 mac-address 0022.9084.073f depi-remote-id 4002
rf-channel 3 cable downstream channel-id 27
rf-channel 3 frequency 633000000 annex B modulation 256qam interleave 32
rf-channel 3 ip-address 11.30.4.2 mac-address 0022.9084.073f depi-remote-id 4003
rf-channel 4 cable downstream channel-id 28
rf-channel 4 frequency 639000000 annex B modulation 256qam interleave 32
rf-channel 4 ip-address 11.30.4.2 mac-address 0022.9084.073f depi-remote-id 4004
In my example we are using a MC5X20H Card in slot 6/1.  We will use Cable6/1/0 for our lab.
- Configure the Cable Bundle
- Configure the Upstreams
- Configure the Downstream Power and Frequency (Please note that if we did not want to run a Primary off the 5X20 we can omit this step)
- Define the associated Modular-Interfaces with this CGD
This command tells the MAC Domain (Technically CGD Domain) that the Modular 1/0/0 Rf-channel 0 using upstream 0-4 are also part of this MAC domain. This means, this host interface carries at this time two Primary Channels – the 5X20 609 Mhz and the Modular-Cable 1/0/0 RF-Channel 0.
downstream Modular-Cable 1/0/0 rf-channel 0 upstream 0-4
*Jan 31 22:17:16.951: %SNMP-5-LINK_DOWN: LinkDown:Interface Modular-Cable1/0/0:0 changed state to down
interface Cable6/1/0
no ip address
downstream Modular-Cable 1/0/0 rf-channel 0-1 upstream 0-4
no cable packet-cache
cable bundle 1
cable downstream channel-id 120
cable downstream annex B
cable downstream modulation 256qam
cable downstream interleave-depth 32
cable downstream frequency 609000000
no cable downstream rf-shutdown
cable upstream max-ports 4
cable upstream 0 connector 4
cable upstream 0 frequency 31500000
cable upstream 0 docsis-mode atdma
cable upstream 0 channel-width 1600000 1600000
cable upstream 0 minislot-size 4
cable upstream 0 power-level 0
cable upstream 0 range-backoff 3 6
cable upstream 0 modulation-profile 221
no cable upstream 0 shutdown
cable upstream 1 connector 1
cable upstream 1 frequency 25000000
cable upstream 1 docsis-mode atdma
cable upstream 1 channel-width 1600000 1600000
cable upstream 1 minislot-size 4
cable upstream 1 range-backoff 3 6
cable upstream 1 modulation-profile 221
no cable upstream 1 shutdown
cable upstream 2 connector 2
cable upstream 2 frequency 18500000
cable upstream 2 docsis-mode atdma
cable upstream 2 channel-width 3200000 3200000
cable upstream 2 minislot-size 2
cable upstream 2 range-backoff 3 6
cable upstream 2 modulation-profile 221
no cable upstream 2 shutdown
cable upstream 3 connector 3
cable upstream 3 frequency 13500000
cable upstream 3 docsis-mode tdma
cable upstream 3 channel-width 200000 200000
cable upstream 3 minislot-size 32
cable upstream 3 range-backoff 3 6
cable upstream 3 modulation-profile 21
no cable upstream 3 shutdown
5.     Cable Bundle Interface Configuration and Provisioning Services
Cable Bundle Interface configuration is typical – since this is layer 3 for the modems we really don’t care that much about anything lower than layer 3 here.
We keep it simple by doing DHCP IP Pools and TFTP-Server directly on the CMTS.
The modem configuration file we use can be a simple DOCSIS 1.1 or 2.0 Modem file. In my case it’s called “chicago1-wcm2.bin”
interface Bundle1
ip address 172.32.0.1 255.255.255.0 secondary
ip address 10.1.1.1 255.255.255.0
cable arp filter request-send 3 2
cable arp filter reply-accept 3 2
tftp-server disk0:WCM.bin
tftp-server disk0:chicago1-wcm2.bin
ip dhcp pool WCM
   network 10.1.1.0 255.255.255.0
   bootfile chicago1-wcm2.bin
   next-server 10.1.1.1
   default-router 10.1.1.1
   domain-name dir
   option 7 ip 10.1.1.1
   option 4 ip 10.1.1.1
Checkpoint:
At this time you should have modems online off the 5X20 Primary DS Channel. You can verify this by “show cable modem” and “show cable modem primary. The Modular-Cable interfaces at this time should both be down/down.
UBR10K2-D3#scm pri
MAC Address    IP Address      Host      MAC          Prim  Num  Primary    DS
                               Interface State        Sid   CPE  Downstream RfId
0015.a3d9.71c5 10.1.1.2        C6/1/0/U2 online(pt)   1     0    C6/1/0     255
0015.a3c0.af49 10.1.1.3        C6/1/0/U0 online(pt)   2     0    C6/1/0     255
<snip>
UBR10K2-D3#sh ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
<snip>
Modular-Cable1/0/0:0       Bundle1         YES unset  down                  down
Modular-Cable1/0/0:1      Bundle1         YES unset  down                  down
Since we defined the modular-cable interfaces under the 6/1/0 Domain, they now exist as interfaces on the CMTS. However, they will remain down/down until we define the percentage of bandwidth allocation.
For interface Modular-Cable 1/0/0:0 I will allocate the maximum percentage allowed which is 96% through the “cable rf-bandwidth-percent 96” command. The reason it is not 100% is due to reservation of at least 4% (sometimes more in real life) of the bandwidth for DOCSIS overhead.
For interface Modular-Cable 1/0/0:1 – since that channel will be carrying both primary channel data and bonding channel data – I will arbitrarily set the bandwidth reserved for the primary channel to 46%.
There is a feature called dynamic bandwidth sharing which allows for dynamic balancing of bandwidth available between a primary and bonding channel on the same physical rf-channel. Search Cisco.com for the feature “CMTS DBS”.
After such configuration the interfaces should come up up.
*Mar  6 10:18:12.515: %LINEPROTO-5-UPDOWN: Line protocol on Interface Modular-Cable1/0/0:0, changed state to up
*Mar  6 10:18:12.515: %SNMP-5-LINK_UP: LinkUp:Interface Modular-Cable1/0/0:0 changed state to up
interface Modular-Cable1/0/0:0
no ip address
cable bundle 1
interface Modular-Cable1/0/0:1
no ip address
cable bundle 1
cable rf-bandwidth-percent 46
Checkpoint:
At this time the CMTS has been configured for Narrowband modems off the Modular and Cable 6/1/0 interfaces. As far as the CMTS knows it is hosting three valid DSs within the 6/1/0 domain at this time. No modems will be able to come online on through the modular interfaces at this time on the 5x20.
You can verify this by a “show controller cable 6/1/0 downstream”
Cable6/1/0 Downstream is up
  Frequency 609.0000 MHz, Channel Width 6 MHz, 256-QAM, Symbol Rate 5.360537 Msps
  FEC ITU-T J.83 Annex B, R/S Interleave I=32, J=4
  Downstream channel ID: 120
  <Snip>
Local total modems 7, modems active 7, total DS flows 8
  NB DS Mo1/0/0:0, STATE: UP
   Frequency 615.0000 MHz 256-QAM,  ANNEX B, R/S Interleave I=32, J=4
   Network Delay 150 (usec)
   Bandwidth (Kbps): 36000,  Load Percent: 0
   Channel ID: 24, US MAP: 0x001F
   Total modems: 0, modems active : 0, total DS flows: 1
  NB DS Mo1/0/0:1, STATE: UP
   Frequency 621.0000 MHz 256-QAM,  ANNEX B, R/S Interleave I=32, J=4
   Bandwidth (Kbps): 17250,  Load Percent: 0
   Channel ID: 25, US MAP: 0x001F
  DS_chan_id  RFID  Interface
    24        0   Mo1/0/0:0
    25        1   Mo1/0/0:1
At this time you will be configuring the EQAM which we will be using as the RFGW10 device.
Checkpoint:
Make sure you are cabled correctly. The UBR10K’s spa GigE on the DS-48 is connected to the port on the associated DS-48 card in the front of the RFGW10 Device. Once this is connected the interface on the RFGW10 should come up/up:
RFGW-10#sh ip int brie
FastEthernet1          172.16.167.47   YES DHCP   up                    up
<snip>
GigabitEthernet3/13    unassigned      YES unset  up                    up
GigabitEthernet3/14    unassigned      YES unset  down                  down
In my setup I simply took the first port off my UBR SPA and hooked it to the slot 3 DS-48 first port. In my example I did not do redundant connections. If you wish, hook the redundant GigE from SPA on UBR to 2nd port on the DS-48 card and it should then come up/up.
The MAC address used earlier in the UBR’s Modular-Controller RF-Channel mappings is the mac address of RFGW10’s interface Gig1/3.
End checkpoint.
We need to map the correct incoming DEPI streams to the correct Qams. For my example I am going to map RF-Channel 0-2 in Qam3/1 and RF-Channel 3,4 on Qam 4/1. This means RF-Channel 0 is represented by Qam3/1.1, RF-channel 1 Qam3/1.2, and RF-Channel 2 Qam3/1.3.
The subinterface to RF-channel mapping is arbitrary – just make sure under the subinterface you define the “cable depi dest-ip xxxx session-id yyyy” to match that of what you have on the UBR’s Modular-Cable controller for your session ID.
- Cable mode depi local
- Cable downstream Frequency xxxxxxx
- Cable downstream modulation [256q|64q]
- Cable downstream annex b
- Cable depi dest-ip zzzzz session-id yyyy
interface Qam3/1.1
cable mode depi local
cable downstream rf-power 50.0
cable downstream frequency 615000000
cable depi dest-ip 11.30.4.2 session-id 4000
snmp trap link-status
interface Qam3/1.2
cable downstream frequency 621000000
cable depi dest-ip 11.30.4.2 session-id 4001
interface Qam3/1.3
cable downstream frequency 627000000
cable depi dest-ip 11.30.4.2 session-id 4002
interface Qam4/1.1
cable downstream frequency 633000000
cable depi dest-ip 11.30.4.2 session-id 4003
interface Qam4/1.2
cable downstream frequency 639000000
cable depi dest-ip 11.30.4.2 session-id 4004
Checkpoint:
At this time your DEPI mappings on the RFGW10 should be accurate – Issue a “show cable depi manual summary” to make sure they are correct. Notice that 4002-4 are IDLE, this is correct as we have not used them in any way on the UBR yet.
RFGW-10#sh cable depi manual sum
List of the Configured Depi Sessions
  ID          Type                State      Qam-info   PWtype
  x-----------x-------------------x----------x----------x--------
  4000        MANUAL_DEPI_OVER_IP ACTIVE     Qam3/01.1  DMPT
  4001        MANUAL_DEPI_OVER_IP ACTIVE     Qam3/01.2  DMPT
  4002        MANUAL_DEPI_OVER_IP IDLE       Qam3/01.3  DMPT
  4003        MANUAL_DEPI_OVER_IP IDLE       Qam4/01.1  DMPT
  4004        MANUAL_DEPI_OVER_IP IDLE       Qam4/01.2  DMPT
RFGW-10#sh cable depi manual 4000
Detailed Info about Session with id# 4000:
                Type               : MANUAL_DEPI_OVER_IP
                Name               :
                State              : ACTIVE
                Remote id         : 0
                DestIP addr        : 11.30.4.2
                Qam slotid         : 3
                Qam portid         : 1
                Qam ch id          : 1
                Payload type       : DEPI_PW_TYPE_D_MPT
                Sync Mode          : ENABLE
                Sync Intl          : 100
                Up time            : 00:48:42
                << Session Statistic >>
                Session is off     : 0
                Broken seq num     : 0
                Bad depi header    : 0
                Bad MPEG sync byte : 0
                In packet rate     : 1042 pps
                In bit rate        : 2088456 bps
                Out bit rate       : 1738344 bps
                << Flow Statistic >>
                Total packet       : 2923407
                Total byte         : 549600516
                Total segment      : 2923407
                Discards           : 0
                Errors             : 0
                Bad pyld size      : 0
                Cmnd buf ovfw     : 0
If you’ve cabled this correctly your cable modems should be able to move between 5x20 Primary, Modular1/0/0:0, and Modular1/0/0:1.
You can now move between them with “test cable dcc” command.
Note that if you wish to use technique 4 of DCC you’ll need to appropriately tune the DEPI offset in the RFGW10 Qam configuration.
UBR10K2-D3#scm pri
0018.19b6.2bd6 10.1.1.5        C6/1/0/U1 online(pt)   9     1    Mo1/0/0:1  1
0014.bfbe.816f 10.1.1.3        C6/1/0/U1 online(pt)   10    0    Mo1/0/0:1  1
0015.a3c0.af49 10.1.1.6        C6/1/0/U1 online(pt)   11    0    Mo1/0/0:1  1
0014.bfbe.8163 10.1.1.9        C6/1/0/U1 online(pt)   12    0    Mo1/0/0:0  0
0018.6897.cf1c 10.1.1.4        C6/1/0/U1 online(pt)   13    0    Mo1/0/0:0  0
0015.a3d9.71c5 10.1.1.10       C6/1/0/U1 online(pt)   14    0    Mo1/0/0:1  1
0015.96d9.f16c 10.1.1.8        C6/1/0/U1 online(pt)   15    0    Mo1/0/0:1  1
0013.11ea.29c9 10.1.1.2        C6/1/0/U1 online(pt)   16    0    Mo1/0/0:0  0
UBR10K2-D3#scm pri
UBR10K2-D3#test cable dcc 0015.a3d9.71c5 mo1/0/0:0 1
0015.a3d9.71c5 10.1.1.10       C6/1/0/U1 offline      14    0.50   1834   0   N N
UBR10K2-D3#scm pri
0015.a3d9.71c5 10.1.1.10       C6/1/0/U1 init(io)     14    0    Mo1/0/0:0  0
UBR10K2-D3#scm pri
0015.a3d9.71c5 10.1.1.10       C6/1/0/U1 online(pt)   14    0    Mo1/0/0:0  0
At this point we should have narrowband modems working off the UBR SPA-24XDS-SFP card. It’s simply configuration of the Interface Wideband and fiber-nodes to get modems to bond and come w-online.
-       Create the interface Wideband
                                          i.    For the Interface wideband you must define the RF-channels you want to use in as bonding channels
                                         ii.    You also must define the interface wideband as part of a cable bundle
                                        iii.    Most field deployments also utilize dynamic bandwidth sharing (DBS)
-       Create the fiber node
                                          i.    This defines the physical topology.
I will create Interface Wideband-Cable1/0/0:0 to represent my first bonding group.
interface Wideband-Cable1/0/0:0
cable bundle 1
cable bonding-group-id 1
cable rf-channel 1 bandwidth-percent 50
cable rf-channel 2 bandwidth-percent 96
Recall that rf-channel 1 is used both for narrowband primaries as well as a bonding channel. This means the bandwidth is shared between the two. Earlier I defined rf-channel 1’s bandwidth within modular1/0/0:1 at 46%. Add it to that allocated for bonding 50% you get exactly 96% which is the maximum allowed allocation.
I will create Interface Wideband-Cable1/0/0:1 to represent the second bonding group.
interface Wideband-Cable1/0/0:1
cable bundle 1
cable bonding-group-id 2
cable rf-channel 3 bandwidth-percent 96
cable rf-channel 4 bandwidth-percent 96
For wideband channel bonding to work we have to define the Cable Fiber Node. A fiber node defines the physical cabling of the plant. In my case, all DS can hit all my modems, so I have defined them to be in the same node.
cable fiber-node 1
  downstream Modular-Cable 1/0/0 rf-channel 0-4
  downstream Cable6/1/0
%Fiber node 1 status changed to Valid state
A fiber node represents the Modular and Cable interfaces which can all hit a subset of modems. There is not necessarily an association with the wideband interfaces. For example, the following definition is redundant and you don’t need fiber node 2 because they overlap.
cable fiber-node 1
cable fiber-node 2
  downstream Modular-Cable 1/0/0 rf-channel 2,3
But this example fiber node IS NOT redundant because it is saying those Modular1/0/0:0-2 can never be seen by modems on Modular1/0/0:3,4
cable fiber-node 1
  downstream Modular-Cable 1/0/0 rf-channel 0-2
cable fiber-node 2
  downstream Modular-Cable 1/0/0 rf-channel 3,4
Checkpoint:
At this time delete the wideband capable modems and they now should come w-online(pt). I only have three WCMs so this is correct!
UBR10K2-D3#scm
        B D
MAC Address    IP Address      I/F       MAC          Prim  RxPwr  Timing Num P I
                                         State        Sid   (dBmv) Offset CPE I P
0015.a3d9.71c5 10.1.1.10       C6/1/0/U1 online(pt)   18    0.50   1833   0   Y N
0014.bfbe.816f 10.1.1.3        C6/1/0/U1 w-online(pt) 19    0.00  1833   0   Y N
0018.19b6.2bd6 10.1.1.5        C6/1/0/U3 online(pt)   20    -0.50  1396   1   Y N
0014.bfbe.8163 10.1.1.9        C6/1/0/U1 w-online(pt) 21    0.00   1833   0   Y N
0015.a3c0.af49 10.1.1.6        C6/1/0/U1 online(pt)   22    -0.50  1833   0   Y N
0015.96d9.f16c 10.1.1.8        C6/1/0/U1 online(pt)   23    0.50   1658   0   Y N
0013.11ea.29c9 10.1.1.2        C6/1/0/U1 online(pt)   24    0.50   1663   0   Y N
0018.6897.cf1c 10.1.1.4        C6/1/0/U1 w-online(pt) 25    0.00   1445   0   Y N
UBR10K2-D3#show cable modem wideband
MAC Address    IP Address      I/F       MAC           Prim  RCC  MD-DS-SG
                                         State         Sid   ID
0014.bfbe.816f 10.1.1.3        C6/1/0/U1 w-online(pt)  19    2    1
0014.bfbe.8163 10.1.1.9        C6/1/0/U1 w-online(pt)  21    1    1
0018.6897.cf1c 10.1.1.4        C6/1/0/U1 w-online(pt)  25    1    1
Notice that in the RFGW10 all DEPI sessions are now ACTIVE – because before we did not utilize those rf-channels which were involved in channel bonding.
RFGW-10#sh cable depi-sessions  manual summ
  4002        MANUAL_DEPI_OVER_IP ACTIVE     Qam3/01.3  DMPT
  4003        MANUAL_DEPI_OVER_IP ACTIVE     Qam4/01.1  DMPT
  4004        MANUAL_DEPI_OVER_IP ACTIVE     Qam4/01.2  DMPT
Congratulations, you now have a simple working MCTMS lab!
See below for show run of UBR and RFGW10:
UBR10K2-D3#sh run
Building configuration...
Current configuration : 18012 bytes
version 12.2
no service pad
service internal
hostname UBR10K2-D3
boot-start-marker
boot system disk0:ubr10k2-k9p6u2-mz.122-33.SCB.bin
boot-end-marker
logging buffered 65535
enable secret 5 $1$gypj$gCHK5fetCrzIzLLB9U7101
no aaa new-model
facility-alarm core-temperature major 58
facility-alarm core-temperature minor 50
facility-alarm core-temperature critical 85
facility-alarm intake-temperature major 54
facility-alarm intake-temperature minor 45
facility-alarm intake-temperature critical 72
card 1 2jacket-1
card 1/0 24rfchannel-spa-1
card 2/1 2cable-dtcc
card 4/0 1gigethernet-hh-1
card 5/0 5cable-mc520u-d
card 6/1 5cable-mc520h-d
cable admission-control preempt priority-voice
no cable qos permission create
no cable qos permission update
cable qos permission modems
cable diaglog active
cable clock dti
ip subnet-zero
no ip domain lookup
no ip dhcp use vrf connected
ip dhcp pool WCM
   domain-name dir
redundancy
mode sso
rf-channel 5 cable downstream channel-id 29
rf-channel 6 cable downstream channel-id 30
rf-channel 7 cable downstream channel-id 31
rf-channel 8 cable downstream channel-id 32
rf-channel 9 cable downstream channel-id 33
rf-channel 10 cable downstream channel-id 34
rf-channel 11 cable downstream channel-id 35
rf-channel 12 cable downstream channel-id 36
rf-channel 13 cable downstream channel-id 37
rf-channel 14 cable downstream channel-id 38
rf-channel 15 cable downstream channel-id 39
rf-channel 16 cable downstream channel-id 40
rf-channel 17 cable downstream channel-id 41
rf-channel 18 cable downstream channel-id 42
rf-channel 19 cable downstream channel-id 43
rf-channel 20 cable downstream channel-id 44
rf-channel 21 cable downstream channel-id 45
rf-channel 22 cable downstream channel-id 46
rf-channel 23 cable downstream channel-id 47
interface FastEthernet0/0/0
ip address 172.16.167.54 255.255.255.224
speed 100
full-duplex
cable bundle 1
cable bundle 1
cable bundle 1
cable cm-status enable 1-2 4-5
cable bundle 1
interface GigabitEthernet4/0/0
no ip address
negotiation auto
interface Cable5/0/0
cable downstream modulation 64qam
cable upstream 0 connector 0
cable upstream 0 docsis-mode tdma
cable upstream 0 modulation-profile 21
cable upstream 1 docsis-mode tdma
cable upstream 1 modulation-profile 21
cable upstream 2 docsis-mode tdma
cable upstream 2 channel-width 1600000 1600000
cable upstream 2 minislot-size 4
cable upstream 2 modulation-profile 21
cable upstream 3 channel-width 1600000 1600000
cable upstream 3 minislot-size 4
interface Cable5/0/1
cable downstream channel-id 121
cable upstream 1 connector 5
cable upstream 2 connector 6
cable upstream 3 connector 7
interface Cable5/0/2
cable downstream channel-id 122
cable upstream 0 connector 8
cable upstream 1 connector 9
cable upstream 2 connector 10
cable upstream 3 connector 11
interface Cable5/0/3
cable downstream channel-id 123
cable upstream 0 connector 12
cable upstream 1 connector 13
cable upstream 2 connector 14
cable upstream 3 connector 15
interface Cable5/0/4
cable downstream channel-id 124
cable upstream 0 connector 16
cable upstream 1 connector 17
cable upstream 2 connector 18
cable upstream 3 connector 19
cable bundle 1
cable upstream 3 s160-atp-10-millisecond-bucket
interface Cable6/1/1
cable downstream channel-id 149
no cable upstream 0 connector
interface Cable6/1/2
cable downstream channel-id 150
interface Cable6/1/3
cable downstream channel-id 151
interface Cable6/1/4
cable downstream channel-id 152
interface Bundle1
no cable ip-multicast-echo
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.167.33
no ip http server
no ip http secure-server
logging cmts cr10k log-level errors
cpd cr-id 1
nls resp-timeout 1
cdp run
control-plane
alias exec scm show cable modem
alias exec ccmd clear cable modem all delete
alias exec ccmr clear cable modem all reset
alias exec dcm debug cable mac-add
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
privilege level 15
password cisco
login
line vty 0 4
exec-timeout 60 0
privilege level 15
password cisco
logging synchronous
login
line vty 5 10
exec-timeout 60 0
privilege level 15
password cisco
logging synchronous
login
cable fiber-node 1
end
RFGW-10#sh run
Current configuration : 11953 bytes
version 12.2
no service pad
service internal
service compress-config
service heartbeat warning-timeout 3
service heartbeat fatal-timeout 5
service heartbeat alive-timeout 300
hostname RFGW-10
boot-start-marker
boot-end-marker
no aaa new-model
hw-module uplink select tengigabitethernet
ip subnet-zero
vtp domain ''
vtp mode transparent
cluster run
power redundancy-mode redundant
spanning-tree mode pvst
redundancy
notification-timer 240000
mode sso
vlan internal allocation policy ascending
interface FastEthernet1
ip address dhcp
speed auto
duplex auto
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface GigabitEthernet1/3
no switchport
ip address 11.30.4.2 255.255.255.0
interface GigabitEthernet1/4
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface TenGigabitEthernet2/1
interface TenGigabitEthernet2/2
interface GigabitEthernet2/3
interface GigabitEthernet2/4
interface GigabitEthernet2/5
interface GigabitEthernet2/6
interface Qam3/1
no ip address
interface Qam3/1.1
cable downstream tsid 37111
cable downstream rf-power 40.0
interface Qam3/1.2
interface Qam3/1.3
interface Qam3/1.4
interface Qam3/2
no ip address
interface Qam3/2.1
interface Qam3/2.2
interface Qam3/2.3
interface Qam3/2.4
interface Qam3/3
no ip address
interface Qam3/3.1
interface Qam3/3.2
interface Qam3/3.3
interface Qam3/3.4
interface Qam3/4
no ip address
interface Qam3/4.1
interface Qam3/4.2
interface Qam3/4.3
interface Qam3/4.4
interface Qam3/5
no ip address
interface Qam3/5.1
interface Qam3/5.2
interface Qam3/5.3
interface Qam3/5.4
interface Qam3/6
no ip address
interface Qam3/6.1
interface Qam3/6.2
interface Qam3/6.3
interface Qam3/6.4
interface Qam3/7
no ip address
interface Qam3/7.1
interface Qam3/7.2
interface Qam3/7.3
interface Qam3/7.4
interface Qam3/8
no ip address
interface Qam3/8.1
interface Qam3/8.2
interface Qam3/8.3
interface Qam3/8.4
interface Qam3/9
no ip address
interface Qam3/9.1
interface Qam3/9.2
interface Qam3/9.3
interface Qam3/9.4
interface Qam3/10
no ip address
interface Qam3/10.1
interface Qam3/10.2
interface Qam3/10.3
interface Qam3/10.4
interface Qam3/11
no ip address
interface Qam3/11.1
interface Qam3/11.2
interface Qam3/11.3
interface Qam3/11.4
interface Qam3/12
no ip address
load-interval 30
interface Qam3/12.1
interface Qam3/12.2
interface Qam3/12.3
interface Qam3/12.4
interface GigabitEthernet3/13
load-interval 30
interface GigabitEthernet3/14
interface Asi3/15
no ip address
interface Qam4/1
no ip address
interface Qam4/1.1
interface Qam4/1.2
interface Qam4/1.3
cable downstream frequency 645000000
interface Qam4/1.4
cable downstream frequency 651000000
interface Qam4/2
no ip address
interface Qam4/2.1
interface Qam4/2.2
interface Qam4/2.3
interface Qam4/2.4
interface Qam4/3
no ip address
interface Qam4/3.1
interface Qam4/3.2
interface Qam4/3.3
interface Qam4/3.4
interface Qam4/4
no ip address
interface Qam4/4.1
interface Qam4/4.2
interface Qam4/4.3
interface Qam4/4.4
interface Qam4/5
no ip address
interface Qam4/5.1
interface Qam4/5.2
interface Qam4/5.3
interface Qam4/5.4
interface Qam4/6
no ip address
interface Qam4/6.1
interface Qam4/6.2
interface Qam4/6.3
interface Qam4/6.4
interface Qam4/7
no ip address
interface Qam4/7.1
interface Qam4/7.2
interface Qam4/7.3
interface Qam4/7.4
interface Qam4/8
no ip address
interface Qam4/8.1
interface Qam4/8.2
interface Qam4/8.3
interface Qam4/8.4
interface Qam4/9
no ip address
interface Qam4/9.1
interface Qam4/9.2
interface Qam4/9.3
interface Qam4/9.4
interface Qam4/10
no ip address
interface Qam4/10.1
interface Qam4/10.2
interface Qam4/10.3
interface Qam4/10.4
interface Qam4/11
no ip address
interface Qam4/11.1
interface Qam4/11.2
interface Qam4/11.3
interface Qam4/11.4
interface Qam4/12
no ip address
interface Qam4/12.1
interface Qam4/12.2
interface Qam4/12.3
interface Qam4/12.4
interface GigabitEthernet4/13
interface GigabitEthernet4/14
interface Asi4/15
no ip address
interface Vlan1
no ip address
ip http server
logging alarm minor
control-plane
banner lcd RFGW-10
line con 0
stopbits 1
line vty 0 4
login
scheduler runtime netinput 100
end
Very nice document. Version with 3G60 cards would also be very helpful.
bhavyangs
Hey Chieh,
This is my Sh Cab modem output for lab setup.
uBR10k#scm
MAC Address    IP Address      I/F       MAC          Prim RxPwr  Timing Num BPI
                                         State        Sid  (dBmV) Offset CPE Enb
0015.cf9d.171d a.b.c.75     C5/1/0/U0 online       170   0.50  1432    1   N
78cd.8e6c.510d a.b.c.122    C5/1/0/U0 w-online     171   0.00  1442    1   N
I want to know w-online modem is bonded to how many channels ... its a 4X4 D3 modem..
Thanks in advance for suggestions.
