09-27-2018 05:11 AM
Dear Cisco Experts.
Customer wants to connect 5406 zl2 Switch which has (Aruba 10G SFP+ transceiver) with Cisco Switch 2960X which also have (SFP-10G-SR-S=) Enterprise class transceiver module.
Is the Aruba 10G SFP+ & Cisco SFP-10G-SR-S are compatible with each other and interconnection will be establish successfully?
09-27-2018 12:23 PM
you can connect with cable between the Cisco SFP+ 10G-SR-S and the Arubu SFP+ 10G SR Transeiver Modules.
But you must use Cisco Transeiver Module in the Cisco Switch and Aruba Modules in the Aruba Switch.
The connection between works.
09-28-2018 04:09 AM
As mentioned the connection may work. However, have heard mixed feedback and success on this, with the particular transceiver SFP-10G-SR-S= and connecting to a non-S Class transceiver. Typically when using this SFP, I recommend using the same SFP on both ends when it comes to the S-Class. If I had a choice when connecting to 3rd party equipment or non-S Class, would recommend using the SFP-10G-SR= which is more industry compliant.
