Afternoon everyone, I'm trying to connect to an APIC using PyATS and the rest.connector.Rest method, but no matter what, I get authentication failures. Here is my testbed file:devices: apic: os: apic type: apic custom: abs...
Hi, I am trying to understand if it is possible to use Cisco Umbrella DNS to inject a custom header into requests. Just to clarify we are not using Cisco SIG. Thanks, John
Dears, I am trying to run a code that could SSH list of devices and come back with data in an external file from these devices.But, at the beginning I am facing some issues regarding netmiko and other features however I have already installed these f...
Hi I'm running NSO 6.1.7.1 with juniper-junos-nc-4.12 NED.I'm trying to use NSO device templates to standardize certain parts of device configurations.In this particular case I'm trying to force a certain set of "apply-groups" on a given Junos config...
Hi,Maapi.commitQueueResult is deprecated and we should use applyTransParams.I need help on how to use applyTransParams.I have the following code:CommitParams cp = new CommitParams();cp.setCommitQueueSync();cp.setNoOverwrite();CommitQueueResult result...
Hi experts,Does anyone knows if it is possible to get the rollback file id inside of the service callback like post-modification etc.?If not do we have a way to get this file for a particular service?Thanks and Best Regards ...
Hello Cisco Community,I've encountered what appears to be a bug in the DataCallbacks class implementation, specifically within the register method that is responsible for ensuring a data handler implements required methods. I would appreciate some gu...
Hello,I need help to recover the cli prompt> after a Dialog conversation:Since PyATS Junos does not have support for linux shell# access, I am using the Dialog conversation to accomplish sending commands in shell mode1- From cli> enter shell with 'ex...
Hello,Working with the Cisco Catalyst Center version 2.3.7.4-75326When I try to call PnP API queries within the C Center web interface or from postman/scripts, I get unexpected results 404. Other APIs work well.Example with "get devices lists":Error ...
got no module error, but when I looked master that it seems trex_subinterface_stats.py is no longer exists in latest master was it replaced by new functions? linux-host0:/opt/trex/DevX-TRex-v23.11-v3.03-34/automation/trex_control_plane/interactive/...
Hi, I am new to YANG/Netconf. Apologies in advance if there is an obvious answer to my question. I am using the Yang models of the https://github.com/YangModels/yang repositories, Python 3.9.2 and pyang 2.5.3 for the following: I am trying to get a f...
I have a set of successful discoveries in DNAC. I know that the devices discovered initially will continue to be updated every 25 minutes. What I'd like though, is to have DNAC regularly run the discoveries. I set up my discovery scopes to scan subne...
Hello all, currently in the company I am at we have a few old models 7960 cisco series VoIP phones. They work almost perfectly fine with the exception that we can not make outgoing calls outside of the company for example calling someone's private ph...
Hello. I am trying to use the Meraki Dashboard API Update Network Alert Settings (https://developer.cisco.com/meraki/api-v1/update-network-alerts-settings/) to change the clients selected for the 'clientConnectivity' type alert. In the documentation ...
Hi Cisco Community team,I have cisco ISR 4331 router on which i want to perform speed test automation so when speed goes down i should get email trigger.use cases.1. every hour speed test automation result on email2. If speed goes beyond x limit IT t...
