on 05-19-2012 11:30 PM
In preparing for CiscoLive! in San Diego, I am provisioning our access layer 3560-E switches. Since things have a tendency to change a lot at an event like CiscoLive! I thought it would be best to make sure our port descriptions are always up-to-date when it comes to reflecting what devices are connected. To help me do that, I wrote up this small EEM applet policy. It will update the port's description based on the CDP neighbor learned on that port. This policy requires EEM 3.2, so you're looking at 12.2(55)SE or higher for the 3560s. It will also work on 3750s and ISR G2 routers running 15.x code.
event manager applet update-port-description
event neighbor-discovery interface regexp GigabitEthernet.* cdp add
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "interface $_nd_local_intf_name"
action 4.0 cli command "description $_nd_cdp_entry_name:$_nd_port_id"
The result of this will be a description like the following on switch ports:
description SDCC_IDF_1.11:TenGigabitEthernet0/1
Forgive me for being daft but what if the Capability is Host? It seems to be interfering with the variable $host. action 4.4 cli command "description $host:$int" is what is in the script.
Jul 23 14:55:29.548 EDT: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: host
Jul 23 14:55:29.683 EDT: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: host
Jul 23 14:55:29.683 EDT: %HA_EM-3-FMPD_ERROR: Error executing applet auto-update-port-description statement 4.4
Dennis,
action 1.1 regexp "(Switch|Router|AIR)" "$_nd_cdp_capabilities_string"
would ensure that only interfaces with capabillities Switch|Router|AIR are triggered upon.
Anyhow, the CDP capabillity is actually stored in the (built in) variable $_nd_cdp_capabilities_string
I think you might be trying this script on a switch with no domain name set? I suspect that in some cases, the trimming of domain name below could cause a empty variable $host.
action 2.0 comment "Trim domain name"
action 2.1 regexp "^([^\.]+)\." "$_nd_cdp_entry_name" match host
Tommy V
Hello. I have a question.
I configured my switch with the actions listed above. I plugged in an access point and the port description was populated as expected. I then moved the access point to another port and it worked again.
However, now I have two ports with the same description, but the WAP is not plugged into one of the ports. How would I get the port to reset or clear the description if the port is down/down, or populate the description with the mac address of the currently connected device (if it does not do CDP) ??? Just clearing the CDP table does not help.
Your help is greatly appreciated. //Craig
At CiscoLive, I use a complimentary applet to default the port. However, the initial idea of this was to be able to find missing APs. If the port was up, then the description was valid. If down, that was the previous spot of the AP. If you want to add the compliment, have a look at:
event manager applet reset-port authorization bypass
event syslog pattern "LINK-3-UPDOWN.*Interface GigabitEthernet.*changed state to down"
action 001 regexp "Interface ([^,]+)" $_syslog_msg match intf
action 002 cli command "enable"
action 003 cli command "show int $intf | inc Description:"
action 004 regexp "STATIC:" $_cli_result
action 005 if $_regexp_result eq 1
action 006 exit 0
action 007 end
action 008 cli command "config t"
action 009 cli command "default interface $intf"
action 010 cli command "interface $intf"
action 011 cli command "switchport trunk encapsulation dot1q"
action 012 cli command "switchport access vlan 2000"
action 013 cli command "load-interval 30"
action 014 cli command "srr-queue bandwidth share 1 30 35 5"
action 015 cli command "priority-queue out"
action 016 cli command "udld port aggressive"
action 017 cli command "mls qos trust dscp"
action 020 cli command "spanning-tree link-type point-to-point"
action 021 cli command "end"
i am trying to configure this script on a Cisco C6880-X-LE running
Cisco IOS Software, c6880x Software (c6880x-IPSERVICESK9_NPE-M), Version 15.1(2)SY5, RELEASE SOFTWARE (fc7)
but i can't find the neighbor-discovery event! Is this softwareversion not supported or is it just hidden?
This commands are supported:
device_name(config-applet)#event ?
application Application specific event
cli CLI event
config Configuration policy event
counter Counter event
env Environmental event
gold GOLD event
identity Identity event
interface Interface event
ioswdsysmon IOS WDSysMon event
ipsla IPSLA Event
mat MAC address table event
nf NF Event
none Manually run policy event
oir OIR event
rf Redundancy Facility event
routing Routing event
rpc Remote Procedure Call event
snmp SNMP event
snmp-notification SNMP Notification Event
snmp-object SNMP object event
syslog Syslog event
tag event tag identifier
timer Timer event
track Tracking object event
Greetings
Seems like a bug to me. While I haven't played with the 6880-X platform yet, I can't see why the ND event detector would not be included here. You might want to open a TAC case to have them investigate.
Okay I will open a TAC Case.
Do you have some kind of "workaround" like a script which does the same but i have to start it by my own?
Greetings
I have recently expanded my automation approach to include reconfiguration based both new devices as well as periodic sweeps. The following is the solution (and description of the solution) we use at the IETF network (with some addresses changed).
The Access and IDF layer switches all contain the following Embedded Event Manager (EEM) configuration. This configuration is defined to automatically detect devices connecting to ports; document those devices via port descriptions; and in the case of a new connection, configure the ports for the device in question. When the device disconnects (i.e., the port goes down), the port is reset to a default configuration and the port description is updated accordingly.
event manager applet detect-ap authorization bypass event tag nd neighbor-discovery interface regexp ^GigabitEthernet0 cdp add maxrun 45 event tag timer timer watchdog time 60 trigger correlate event nd or event timer action 001 cli command "enable" action 002 set intfs "" action 003 if $_event_type_string eq "timer watchdog" action 004 cli command "show int status | inc connected" action 005 set cres $_cli_result action 006 foreach line "$cres" "\n" action 007 regexp "^([^[:space:]]+)[[:space:]]" "$line" match intf action 008 if $_regexp_result eq "1" action 009 cli command "show lldp neighbor $intf detail" action 010 set lcres $_cli_result action 011 set port_id "" action 012 set sys_name "-" action 013 set plat "UNKNOWN" action 014 regexp "Port id: ([^[:space:]]+)" $lcres match port_id action 015 regexp "System Name: ([^[:space:]]+)" $lcres match sys_name action 016 regexp "K9W7-" $lcres action 017 if $_regexp_result eq 1 action 018 set plat "AP" action 019 else action 020 regexp "K9W8-" $lcres action 021 if $_regexp_result eq 1 action 022 set plat "LWAP" action 023 else action 024 regexp "C3560E Software|C3560C Software|Catalyst 4500 L3 Switch Software" $lcres action 025 if $_regexp_result eq 1 action 026 set plat "SWITCH" action 027 else action 028 regexp "IETF_Probe:([^[:space:]]+)" $lcres match hn action 029 if $_regexp_result eq "1" action 030 set plat "PROBE" action 031 set sys_name $hn action 032 else action 033 set plat "DEVICE" action 034 end action 035 end action 036 end action 037 end action 038 append intfs " $intf~$port_id~$sys_name~$plat" action 039 end action 040 end action 041 else action 042 regexp "K9W7-" "$_nd_cdp_version" action 043 set plat "UNKNOWN" action 044 if $_regexp_result eq 1 action 045 set plat "AP" action 046 else action 047 regexp "K9W8-" "$_nd_cdp_version" action 048 if $_regexp_result eq "1" action 049 set plat "LWAP" action 050 else action 051 regexp "cisco (WS-C3560CG-8PC-S|WS-C3560X)" "$_nd_cdp_platform" action 052 if $_regexp_result eq "1" action 053 set plat "SWITCH" action 054 end action 055 end action 056 end action 057 set intfs "$_nd_local_intf_name~$_nd_port_id~$_nd_cdp_entry_name~$plat" action 058 end action 059 string trim $intfs action 060 cli command "config t" action 061 set config_change "0" action 062 foreach intf $_string_result action 063 regexp "^([^~]+)~([^~]*)~(.*)" "$intf" match lif pid rest action 064 regexp "^([^~]*)~([^~]*)" "$rest" match sysn plat action 065 cli command "do show interface $lif | inc Description:" action 066 set cdescr "" action 067 regexp "Description: ([^\n]+)" $_cli_result match cdescr action 068 string trim $cdescr action 069 set cdescr $_string_result action 070 if $plat eq "AP" action 071 syslog priority notifications msg "$sysn" action 072 cli command "interface $lif" action 073 if $cdescr ne "AP : $sysn:$pid" action 074 cli command "description AP : $sysn:$pid" action 075 set config_change "1" action 076 end action 077 if $_event_type_string ne "timer watchdog" action 078 cli command "switchport mode trunk" action 079 cli command "switchport trunk allowed vlan 1,2152,2160,2168,1998,1999,2176" action 080 cli command "spanning-tree portfast trunk" action 081 set config_change "1" action 082 end action 083 else action 084 if $plat eq "LWAP" action 085 cli command "int $lif" action 086 if $cdescr ne "AP : $sysn:$pid" action 087 cli command "description AP : $sysn:$pid" action 088 set config_change "1" action 089 end action 090 if $_event_type_string ne "timer watchdog" action 091 cli command "switchport mode trunk" action 092 cli command "switchport trunk allowed vlan 1" action 093 cli command "spanning-tree portfast trunk" action 094 set config_change "1" action 095 end action 096 end action 097 end action 098 if $plat eq "SWITCH" action 099 cli command "interface $lif" action 100 if $cdescr ne "Core : $sysn:$pid" action 101 cli command "description Core : $sysn:$pid" action 112 set config_change "1" action 113 end action 114 if $_event_type_string ne "timer watchdog" action 115 wait 1 action 116 cli command "do ping 10.1.1.1" action 117 cli command "do show arp 10.1.1.1" action 118 regexp "([0-9a-f\.]+)[[:space:]]+ARPA" "$_cli_result" match mac action 119 cli command "do show mac address-table address $mac" action 120 regexp "DYNAMIC[[:space:]]+([A-Za-z0-9/]+)" "$_cli_result" match port action 121 if $_nd_short_local_intf_name eq "$port" action 122 cli command "ip dhcp snooping trust" action 123 cli command "no ipv6 nd raguard" action 124 cli command "no ipv6 dhcp guard" action 125 cli command "ipv6 nd raguard attach-policy uplink-policy" action 126 else action 127 cli command "no ip dhcp snooping trust" action 128 cli command "ipv6 nd raguard" action 129 cli command "ipv6 dhcp guard" action 130 cli command "no ipv6 nd raguard attach-policy uplink-policy" action 131 end action 132 set config_change "1" action 133 end action 134 else action 135 if $plat eq "PROBE" action 136 if $cdescr ne "Probe : $sysn:$pid" action 137 cli command "interface $lif" action 138 cli command "description Probe : $sysn:$pid" action 139 set config_change "1" action 140 end action 141 else action 142 if $plat eq "DEVICE" action 143 if $sysn ne "-" action 144 if $cdescr ne "Generic : $sysn:$pid" action 145 cli command "interface $lif" action 146 cli command "description Generic : $sysn:$pid" action 147 set config_change "1" action 148 end action 149 end action 150 end action 151 end action 152 end action 153 end action 154 cli command "end" action 155 if $config_change eq "1" action 156 cli command "write mem" action 157 end ! event manager applet reset-port authorization bypass event syslog pattern "LINK-3-UPDOWN.*Interface .*GigabitEthernet0.*changed state to down" action 001 regexp "Interface ([^,]+)" "$_syslog_msg" match intf action 002 cli command "enable" action 003 cli command "show int $intf | inc Description:" action 004 regexp "Description: (Was )*([^\n\[]+)" $_cli_result match ignore descr action 005 set idescr "default" action 006 if $_regexp_result eq 1 action 007 string trim $descr action 008 if $_string_result ne "default" action 009 set idescr "Was $_string_result [last seen: $_event_pub_time]" action 010 end action 011 end action 012 cli command "config t" action 013 cli command "interface $intf" action 014 cli command "description $idescr" action 015 cli command "no ip dhcp snooping trust" action 016 cli command "ipv6 nd raguard" action 017 cli command "ipv6 dhcp guard" action 018 cli command "no ipv6 nd raguard attach-policy uplink-policy" action 019 cli command "switchport trunk allowed vlan all" action 020 cli command "end" action 021 cli command "write mem"
This configuration consists of two EEM applet policies. The first few lines of the first policy define the applet that detects new devices.
1 event manager applet detect-ap authorization bypass 2 event tag nd neighbor-discovery interface regexp ^GigabitEthernet0 cdp add maxrun 45 3 event tag timer timer watchdog time 60 4 trigger 5 correlate event nd or event timer
Line 1 defines an applet called "detect-ap" and indicates that it should bypass AAA command authorization (if configured). We do not currently use AAA authz at the IETF.
This applet will react to two events. Line 2 defines the first event: react to the addition of a new CDP neighbor. If a new neighbor is learned on a port that matches the regular expression of ^GigabitEthernet0 (note: this is for 3560X switches; 3560CG will use "GigabitEthernet0/[1-8]$"), then the applet will trigger. The reason for these limiting regular expressions is to prevent detection from happening on typical uplink ports. Those are statically configured and their descriptions will be handled via the second event (as they don't need reconfiguration). The "maxrun 45" parameter says that this applet policy is allowed to run for 45 seconds and no more. The default maximum runtime is 20 seconds, but because of the logic and commands within the applet, it could run longer than 20. If the policy is still running after 45 seconds, it is forcibly terminated.
Line 3 defines the second event. This event will trigger the policy to run every 60 seconds.
Line 5 says that the policy will run if either the CDP neighbor event occurs or the timer pops.
This next set of code is executed only if the timer pops. It will not execute when the new CDP neighbor event occurs. This code will run through the output of show int status | inc connected then checking each connected port for its LLDP neighbor. Each port with a neighbor is added to the intfs string with the values of the local port name, the remote port name, the remote system name, and the remote platform type. We use '~' to delimit these values as ';' is special to Rancid, and other delimiters might actually appear in interface names. The following device types are called out specifically:
This next block parses the built-in variables for the new CDP neighbor event. This code is only executed when the new CDP neighbor event occurs. It is designed to detect an AP, LWAP or SWITCH. Note how it doesn't detect the Catalyst 4500X. This is because that switch (the core) will only show up on uplink ports (e.g., Ten1/1) which are not looked at for new CDP neighbors.
This next [large] block of code walks through each interface listed in the intfs string and checks the resulting platform. Actions 063 and 064 might looks weird. The regexp action can only accept a total of four match variables (and the first is the whole match itself). So, in order to match four parameters, the pattern needs to be broken into two pieces. The lines that follow the regexp actions will apply the necessary configuration changes to the given port (if needed). If the event is a timer-triggered event, only the port description will ever be changed. If a new CDP neighbor triggered the event, then additional configuration will be applied.
For an autonomous AP, the port will be configured to be a trunk carrying the typical user VLANs. For a lightweight AP, the port will be reconfigured to be a trunk only carrying VLAN 1 (the management VLAN). For an inter-switch link, the port will be reconfigured to be a trunk. Then things can get interesting. The switch will ping the default gateway on VLAN 1. It will then see if the ARP that is learned for that IP is through the port for which the new CDP neighbor event occurred. If it is, then this is configured to be an uplink port and EEM will mark the port as such by adding the RA guard policy and trusting the port for DHCP snooping. If the ARP is learned through a different port, then the port is protected as a downlink trunk port.
For probes or other generic devices, the port is left as it currently is with only the description being changed. For all ports regardless of the event that triggered the policy, the port's description will be updated to reflect the device that is hanging off of it.
This last little bit will trigger a write mem (copy the running config to startup) if the configuration was actually changed. By checking this we can save the flash from excessive writes.
So, why use CDP instead of LLDP for the new neighbor event? That's how it started out, and for the config changes we need to do, the devices already support CDP. Therefore, I didn't see a need to change at this point.
The second applet handles the case when the port goes down. It's much simpler because all ports should be reset to a more common config.
1 event manager applet reset-port authorization bypass 2 event syslog pattern "LINK-3-UPDOWN.*Interface .*GigabitEthernet0.*changed state to down"
Line 1 defines the applet itself, and line 2 says that the event that will trigger this applet is a syslog event that checks if a port went down that matches the regular expression "GigabitEthernet0" (note: this is for 3560X switches; for 3560CG switches the pattern is "GigabitEthernet0/[1-8],"). Just like the first applet, we ignore typical (statically pre-configured) uplink ports (e.g., Ten1/1 on 3560X and Gi0/10 on 3560CG).
The biggest piece of logic in this applet is here. The applet extracts the current description of the port and creates a new description in the format of, "Was ORIGINAL_DESCRIPTION [last seen: TIME]". The TIME here is the time of the event. This way, we know what was connected to the port and when it was last seen.
The config applied is the default config for the port, waiting for a new device (or end user host) to plugin.
last year (i think in november) i open a tac case.
the response was: wait for the new firmware. i still wait
greetz
flo
Great script!
But I have a problem with the Trim domain name part.
Some of my host doesn't have the domaine name on it.
and in this case the $host is empty.
I try to change for the following regex (who work on a simulator on internet): ^([^\.]*)\.
for a name like wa-cht-03 it's empty
but it doesn't work at all on Cisco !?
What is the flavor of the regex ?
And how can I trim host id to take all until the first .
thanks,
arno
Use the regexp:
Thanks it works well.
I have another problem with this line:
action 4.23 regexp "Description: ([a-zA-Z0-9:/\-]*)([a-zA-Z0-9:/\-\ ]*)" "$_cli_result" olddesc olddesc_sub1
My description on the port end like this:
SE-UST-221 / WS-C3560V2-24PS / Gi0/2
and on the log I got this:
Aug 16 11:16:47.935: %HA_EM-6-LOG: auto-update-port-description: EEM script updated description on TenGigabitEthernet1/1/22 from Description: SE-UST-221 / WS to Description: SE-UST-221 / WS-C3560V2-24PS / Gi0/2 and saved config
On $olddesc I have:Description: SE-UST-221 / WS
and on $olddesc_sub1: SE-UST-221
so it's not stripping out Description: and not filling $olddesc_sub1 correctly
And the test (if an updated is needed) is based on $olddesc_sub1 but the logging information is based on $olddesc
why is that ?
You seem to be using Colin's policy as an example. If you look at the big one I posted above, I use this to get the current description:
Then the value you want is stored in the $descr variable.
I'm using the following script that was published earlier in this discussion and its working fine. I want to trim the output but not being a script guy, I can't find where it does this. I don't want the neighbor port to be written out (Gi0). Here is how it looks now: SWITCH1-2:Gi0
event manager applet auto-update-port-description authorization bypass
description "Auto-update port-description based on CDP neighbor info"
event neighbor-discovery interface regexp .*GigabitEthernet[0-9]/[0-9]+$ cdp add
action 0.0 comment "Event line regexp: Deside which interface to auto-update description on"
action 1.0 comment "Verify CDP neighbor to be Switch or Router"
action 2.1 regexp "^([^\.]+)" "$_nd_cdp_entry_name" match host
action 3.0 comment "Convert long interface name to short"
action 3.1 string first "Ethernet" "$_nd_port_id"
action 3.2 if $_string_result eq "7"
action 3.21 string replace "$_nd_port_id" 0 14 "Gi"
action 3.3 elseif $_string_result eq 10
action 3.31 string replace "$_nd_port_id" 0 17 "Te"
action 3.4 elseif $_string_result eq 4
action 3.41 string replace "$_nd_port_id" 0 11 "Fa"
action 3.5 end
action 3.6 set int "$_string_result"
action 4.0 comment "Check old description if any, and do no change if same host:int"
action 4.1 cli command "enable"
action 4.11 cli command "config t"
action 4.2 cli command "do show interface $_nd_local_intf_name | incl Description:"
action 4.21 set olddesc "<none>"
action 4.22 set olddesc_sub1 "<none>"
action 4.24 if $olddesc_sub1 eq "$host:$int"
action 4.25 syslog msg "EEM script did NOT change desciption on $_nd_local_intf_name, since remote host and interface is unchanged"
action 4.26 exit 10
action 4.27 end
action 4.3 cli command "interface $_nd_local_intf_name"
action 4.5 cli command "do write"
action 4.6 syslog msg "EEM script updated description on $_nd_local_intf_name from $olddesc to Description: $host:$int and saved config"
action 6.0 exit 1
end
clear cdp table
wr
Ken-
Change line 4.24 to
action 4.4 cli command "description $host"
