jawicks
The following devices have passed the OpenReach MCT testing process or have been given a pass status based upon their similarity to other models which have already achieved a pass (indicated with "=" in the pass-date column below). This table will be updated as more devices are passed through the MCT certification process.
Device P/N IOS Ver DSL Chipset Chipset H/W Chipset F/W Pass Date Comment
C887VA-K9 15.4(2)T1 Broadcom BCM6368 39m_B_38h3_24h Oct 2014 Baseline 887 unit
C897VA-K9 15.4(2)T1 Broadcom BCM6368 39m_B_38h3_24h Oct 2014 Baseline 897 unit
CISCO887VA-K9 = Broadcom BCM6368 39m_B_38h3_24h = original generation 887
CISCO887VA-M-K9 = Broadcom BCM6368 39m_B_38h3_24h = original generation 887 (Annex-M)
CISCO887VA-SEC-K9 = Broadcom BCM6368 39m_B_38h3_24h = original 887 with IPsec s/w bundle
C887VAM-K9 = Broadcom BCM6368 39m_B_38h3_24h = baseline 887VA (with Annex-M)
C887VA-W-E-K9 = Broadcom BCM6368 39m_B_38h3_24h = baseline 887VA with integrated WiFi
C887VAM-W-E-K9 = Broadcom BCM6368 39m_B_38h3_24h = baseline 887VA (Annex-M) + WiFi
C887VA-V-K9 = Broadcom BCM6368 39m_B_38h3_24h = baseline 887VA with integrated FXS POTS
C887VA-V-W-E-K9 = Broadcom BCM6368 39m_B_38h3_24h = C887VA-V-K9 + WiFi
C887VA-CUBE-K9 = Broadcom BCM6368 39m_B_38h3_24h = C887VA with CUBE s/w license bundle
C887VAG+7-K9 = Broadcom BCM6368 39m_B_38h3_24h = C887VA with integrated 3G
C887VAMG+7-K9 = Broadcom BCM6368 39m_B_38h3_24h = C887VAM-K9 with integrated 3G
C887VAGW+7-E-K9 = Broadcom BCM6368 39m_B_38h3_24h = C887VAMG+7-K9 with integrated WiFi
C887VA-WD-E-K9 = Broadcom BCM6368 39m_B_38h3_24h = C887VA with dual-band WiFi
C887VAG-4G-GA-K9 = Broadcom BCM6368 39m_B_38h3_24h = C887VA with integrated 3G/4G
C897VA-M-K9 = Broadcom BCM6368 39m_B_38h3_24h = baseline C897VA (Annex-M)
C897VAW-E-K9 = Broadcom BCM6368 39m_B_38h3_24h = C897VA-K9 with integrated WiFi
C897VAM-W-E-K9 = Broadcom BCM6368 39m_B_38h3_24h = C897VA-M-K9 with integrated WiFi
C897VAG-LTE-GA-k9 = Broadcom BCM6368 39m_B_38h3_24h = C897VA-K9 with integrated 3G/4G
C897VAMG-LTE-GA-K9 = Broadcom BCM6368 39m_B_38h3_24h = C897VA-M-K9 with integrated 3G/4G
NIM-VAB-A XE3.14.0 Broadcom BCM63168 39p1 July 2015 NIM Module for ISR4xxx - conditional pass, NIM fails OAM loopback testing which may impact on-line diagnostics.
EHWIC-VA-DSL-A 15.4(2)T1 Broadcom BCM6368 39m_B_38h3_24h Sept 2015 EHWIC plugin for ISR-G2 routers; c1900, c2900, c3900, etc.
EHWIC-VA-DSL-A 15.6(3)M Broadcom BCM6368 A2pv6C039t Jan 2016 Embedded FW and SDK Change with 15.6(3)M requires version 39t and it is not backward compatible with previous versions.
EHWIC-VA-DSL-M 15.4(2)T1 Broadcom BCM6368 39m_B_38h3_24h Sept 2015 EHWIC plugin for ISR-G2 routers; c1900, c2900, c3900, etc.
C1113-8P 16.9 Broadcom BCM63138 A2pvfbH043n Nov 2018 VDSL only. G.FAST is going through certification.
C927-4P 15.8 Broadcom BCM63168 A2pv6F039x8 June 2019
C1117-4P 16.9 Broadcom BCM63168 A2pvbF039t.d26d June 2019 IOS-XE versions 16.6-16.10
C1117-4P 16.11 Broadcom BCM63168 A2pv6F039x8
June
2019
IOS-XE version 16.11 onwards
C1117 17.4 Broadcom
A2pv6F039x8.d26d
November 2021
jawicks
 Nothing planned for Annex-M at the moment................if you can reach out to your usual Cisco account-team and ask them to ping me with the details, then we can weigh the merits of getting them passed through the OpenReach certification process, as it's not a trivial amount of effort (plus I don't have the Annex-M hardware available right now, because we're normally running on Annex-A flavour).
jackbro
C1117 with IOS-XE 17.4 is now certified on VDSL.
