Joe Clarke
The EASy Installer is a tclsh script that provides a menu interface to install Embedded Automation Systems (EASy) packages.  This document tracks the latest version of the EASy Installer script and the configuration and deployment guide that accompanies it.
More about the Embedded Automation Systems initiative can be found at http://www.cisco.com/go/easy .
frbird
Is this compatible with NX-OS?
Joe Clarke
No, unfortunately the EEM and Tcl capabilities of NX-OS do not support the EASy framework.
HenryPerez2009
Community Member
Hi Joseph!
I am new to the whole EEM service, and am looking to learn as much as I can about it. But for starters any ideas on how do I confirm the IOS we're using supports it?
Thanks in advanced for your help.
Henry
Joe Clarke
