on 06-23-2014 05:19 AM
This ISR sample application uses a tclsh script managed by an EEM applet to stream NMEA formatted location data in UDP packets (with configurable port number) to a defined target. TCLSH script is in the attached zip file and also requires the following CLI commands.
! CLI commands required:
event manager environment server "your server ip address"
event manager environment udp_port "your udp port"
event manager applet NMEA
event syslog pattern "LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular[0-9\/]+, changed state to up" maxrun 31536000
action 010 cli command "enable"
action 020 syslog msg "NMEA streaming starting now"
action 030 cli command "tclsh flash:stream_NMEA2.tcl $server $udp_port"
aaa new-model
aaa authentication login nologin none
aaa authorization exec nologin none
controller Cellular <number>
lte gps mode standalone
"lte gps nmea ip" for 819. "lte gps nmea" for all other platforms
Its connecting:
STJ-TEST-KEN#sh users
Line User Host(s) Idle Location
0 con 0 idle 00:24:21
3 tty 3 Async interface 00:00:00
7 tty 7 incoming 00:00:00 192.168.252.129
*705 vty 0 admin idle 00:00:00 192.168.101.130
707 vty 2 admin idle 00:00:20 192.168.101.130
Interface User Mode Idle Peer Address
STJ-TEST-KEN#sh line
Tty Line Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 0 CTY - - - - - 0 0 0/0 -
1 1 TTY 9600/9600 - - - - - 0 0 0/0 -
2 2 TTY 9600/9600 - - - - - 0 0 0/0 -
A 3 3 TTY - inout - - - 0 0 0/0 Ce0
4 4 TTY 9600/9600 - - - - - 0 0 0/0 -
* 7 7 TTY - inout - - - 9 1365 0/0 NM7
8 8 TTY - - - - - 0 0 0/0 Ce1
1/3 69 TTY 9600/9600 - - - - - 0 0 0/0 -
1/4 70 TTY 9600/9600 - - - - - 0 0 0/0 -
1/5 71 TTY 9600/9600 - - - - - 0 0 0/0 -
1/6 72 TTY 9600/9600 - - - - - 0 0 0/0 -
* 705 705 VTY - - - - 23 3 0 0/0 -
706 706 VTY - - - - 23 1 0 0/0 -
* 707 707 VTY - - - - 23 2 0 0/0 -
708 708 VTY - - - - 23 0 0 0/0 -
709 709 VTY - - - - 23 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
5-6, 9-68, 73-704
debug ip packet using an ACL that limits it to the UDP traffic. Need to verify that the packets are being sent. Run TCPdump on the server to see if they are being received. Firewall update needed on the server running NMEA application?
I think it would be better if we got on a web ex to take a look. you can contact me at dafrey@cisco.com to set up a time to troubleshoot.
I don't believe the packers are being sent. There is a firewall in between and I don't see the packets hitting the firewall. I will do the debug and see what it says though. Not much traffic on it so should be fine.
Also, verify that the environment variables do not have quotes. If they have quotes I believe they will be passed as variable syntax.
event manager environment server 192.168.0.125
event manager environment udp_port 12345
Might be it. No traffic from packet debug.
No change... I have starting the script from the command lin e and below is the output when I clear line tty 7:
STJ-TEST-KEN#tclsh flash:nmea_829_gps.tcl $server $udp_port
server and port = $server $udp_port
invalid service name: "$udp_port" could not be converted to a port number.
while executing
"fconfigure $sock -remote [list $server $sudp_port]"
(file "flash:nmea_829_gps.tcl" line 62)
STJ-TEST-KEN#tclsh flash:nmea_829_gps.tcl 192.168.108.74 30176
server and port = 192.168.108.74 30176
error reading "sock1": broken pipe
while executing
"gets $fd line"
(file "flash:nmea_829_gps.tcl" line 1)
STJ-TEST-KEN
Not sure if that sheds any light.
It seems to do what its supposed to do by reverse telnet ting in, then it sits there and does nothing.
Just an update on this.
I am still struggling to get a working solution. The IR829 platform has a streaming parameter where I can send a directed UDP stream back to my GPS server. This works and the format is: Red being the line that created the stream....
controller Cellular 0
lte gps nmea ip udp 192.168.252.129 192.168.108.74 30176
To try to address my GPS excessive data consumption issue I added in the following to schedule the turn and off of the red line every 60 seconds and let it run for 5 and shut it down again:
event timer watchdog time 60
action 015 cli command "conf te"
action 020 cli command "controller cellular 0"
action 030 cli command "lte gps nmea ip udp 192.168.252.129 192.168.108.74 30176"
action 040 wait 5
action 050 cli command "no lte gps nmea ip udp 192.168.252.129 192.168.108.74 30176"
On a reboot of the router this works for the first time and them no more streaming NMEA until the router is rebooted and the applet removed.
Is there an issue with the EEM applet?
TAC is no help at all at this point.
I'd like to revive this thread. I'm having the same problem as the original poster with the as-written script and config not sending out data. I added in the line to rebroadcast and the cell modem just cycles up and down and nothing gets sent. Specifically I added this line to the cell controller
lte gps nmea ip udp 1.2.3.4 <my NMEA ingester ip> <my NMEA ingester port>
the 1.2.3.4 is the loopback IP from the tcl script. I haven't made any modifications to the NMEA tcl script.
I'm running ir800-universalk9-mz.SPA.156-3.M
When I was having the issue with no data sending, I found somewhere in the forums to remove one of the lines from the original script. Once I did that, the streaming started to work.. Also, we have an entry to pause from sending a steady stream, I believe that's where the counter is..
Here's our latest tcl script we're using on:
Cisco C819G-4G-A-K9
c800-universalk9-mz.SPA.154-3.M6a.bin
package require udp
set server [lindex $argv 0]
set sudp_port [lindex $argv 1]
puts "server and port = $server $sudp_port"
set intf [ios_config "int loopback 7" "description DO NOT REMOVE" "ip add 1.2.3.4 255.255.255.255"]
set pt [exec show line | inc NM]
regexp {.?\s+(\d+)\s+TTY} $pt -> line
set cl [exec clear line $line]
set ttyline [ios_config "line $line" "login authentication nologin"]
set transprt [ios_config "line $line" "transport input all"]
set sock [udp_open]
after 1000
set IP "1.2.3.4"
set port [expr 2000 + $line]
set fd [socket $IP $port]
set counter 120
while {[gets $fd line] } {
incr counter
if [ regexp {^\$GPRMC} $line ->line ] {
if {$counter >= 120} {
puts -nonewline $sock $line
flush $sock
set counter 0
Thanks - that works!
How can a UDP listener service determine the specific device ID of the sender of the NMEA strings among many Cisco devices without provisioning static IP addresses for each Cisco device?
if we use this script on lot of routers we need add hostname to line.
how we can do it on script?
WBR, Daniil
I'm back to trying to control the GPS stream on a c1111-4plteea.
I can't seem to control how often the GPS data is sent.. The router does send it automatically without the script, but over 200x's per second to the server... way too much data..
Anyone have an idea of what is need to control the GPS data flow on a c1111-4plteea?
