SunilKhanna
Configuring Private Hosts on Catalyst 6500 switch running Cisco IOS Software
1] Configure MAC-List
ROUTER#conf t
Enter configuration commands, one per line. End with CNTL/Z.
ROUTER(config)#private-hosts mac-list BRAS 0000.7777.3333
2]] Configure Private Hosts vlan-list
ROUTER(config)#private-hosts vlan-list 777,888
3] Configure Promiscuous Device
ROUTER(config)#private-hosts promiscuous BRAS vlan-list 888
4] Enable private Hosts feature globally
5] Configure Vlans and Enable Private Hosts modes on the interface
ROUTER(config)#vlan 777
ROUTER(config-vlan)#exit
ROUTER(config)#vlan 888
ROUTER(config)#
ROUTER(config)#int g3/2
ROUTER(config-if)#switchport
ROUTER(config-if)#switchport trunk encapsulation dot1q
ROUTER(config-if)#switchport mode trunk
ROUTER(config-if)#switchport trunk allowed vlan 777,888
ROUTER(config-if)#access-group mode prefer port
ROUTER(config-if)#private-hosts mode isolated
ROUTER(config-if)#int g4/12
ROUTER(config-if)#switchport trunk allowed vlan 888
ROUTER(config-if)#private-hosts mode promiscuous
ROUTER(config-if)#int f1/35
ROUTER(config-if)#no sh
6] Verify Private Hosts feature is enabled and Redirect Index is programmed
ROUTER#sh private-hosts configuration Private hosts enabled. BR INDEX 7 All mandatory configurations configured Privated hosts vlans lists: 777,888 Privated promiscuous MAC configuration: A '*' mark behind the mac list indicates non-existant mac-list
MAC-list VLAN list
BRAS                         888
ROUTER#
7] Verify Private Hosts is enabled on all the interfaces
ROUTER#sh private-hosts interface configuration Private hosts enabled Debug Events: 0 Acl: 0 API: 0 Promiscuous interface list
GigabitEthernet4/12
Isolated interface list
FastEthernet1/35 GigabitEthernet3/2
Mixed mode interface list
ROUTER#
8] Verify that tcam redirect is programmed with Promiscuous/Mixed ports using “show tcam redirect” in SP
ROUTER#remote command switch sh tcam red
TCAM Redirect Indices
       offset: 0x7E00
       Indx 0 (0x7E00)  unique: 0 count_allocations: 0 entries: 0  Portlist:
       Indx 1 (0x7E01)  unique: 0 count_allocations: 2 entries: 0  Portlist: 15/1
       Indx 2 (0x7E02)  unique: 0 count_allocations: 2 entries: 0  Portlist: 15/1
       Indx 3 (0x7E03)  unique: 0 count_allocations: 2 entries: 0  Portlist: 15/1
       Indx 4 (0x7E04)  unique: 0 count_allocations: 2 entries: 0  Portlist:
       Indx 5 (0x7E05)  unique: 1 count_allocations: 1 entries: 0  Portlist: 15/1
       Indx 6 (0x7E06)  unique: 1 count_allocations: 1 entries: 0  Portlist: 15/1
       Indx 7 (0x7E07)  unique: 0 count_allocations: 1 entries: 1  Portlist: 4/12
ROUTER#
9] Verify TCAM entries in Isolated Ports - Traffic with Src MAC=BRAS MAC should be denied - Traffic with Destination MAC=BRAS MAC should be permitted - Broadcast traffic should be redirected - ANY OTHER TRAFFIC should be denied
ROUTER#sh tcam int g3/2 acl in other module 3
  • Global Defaults shared
Entries from Bank 0
Entries from Bank 1
   deny         other host 0000.7777.3333 any
   permit       other any 3333.0000.0000 ffff.0000.0000
   permit       other any 0100.5e00.0000 ffff.ff80.0000
   permit       other any host 0000.7777.3333
   redirect     other any host ffff.ffff.ffff
   deny         other any any
ROUTER# ROUTER#sh tcam int f1/35 acl in o ROUTER#sh tcam int f1/35 acl in other m ROUTER#sh tcam int f1/35 acl in other module 1
Entries from Bank 0
Entries from Bank 1
   deny         other any any
ROUTER#
10] Verify tcam entries in Promiscuous Port - Traffic with Source MAC=BRAS MAC should be permitted - Any other traffic should be denied
ROUTER#sh tcam int g4/12 acl in other
Entries from Bank 0
Entries from Bank 1
   permit       other host 0000.7777.3333 any
   deny         other any any
ROUTER#
11] Verify that BRAS mac-address is installed with below flags: Type=Static Learn= Yes
ROUTER#sh mac-address-table | i 0000.7777
  • 888 0000.7777.3333 static Yes - <drop>
ROUTER#
