SunilKhanna
    Introduction
    Multicast-Routing in IPv6 environment is explicitly enabeled in Global Configuration mode by command "ipv6 multicast-routing". The effect of this command is seen on all IPv6-enabled interfaces on the router which are then automatically enabled also for PIMv6. As this is the default configuration of each interface, the ipv6 pim command is assumed and does not appear in the interface configuration.  When PIMv6 is enabled on an interface, the
    interface always operates in sparse mode. PIM-SM (Sparse-Mode) uses unicast routing to provide reverse-path information for multicast tree building, but it is not dependent on any particular unicast routing protocol.
    Note: To disable PIM on a particular interface, command used is "no ipv6 pim" (interface level).
    Prerequisite
    Understanding Of Multicast Concepts
    Understanding of IPv6 Addressing
    Understanding of IPv6 OSPF Routing Protocol
    Background
    In this document, Router R1, R2 and R3 are enabled with PIM-SM (Sparse Mode), command "ipv6 multicast-routing". . They are also configured with IPv6 OSPF unicast routing. A multicast group is created on R1 and is configured to be a respondent for this group by interface level command "ipv6 mld join-group FF08::10". We are configuring Router R3 to be the Rendezvous Point for this group.
    Note: All configuration is tested on Cisco 7200 Series Router running on IOS Version  15.1(3)S3 Advance IP Services Image.
    Topology Diagram
    Configuration
    R1
    R2R3
    hostname R1
    no ip domain lookup
    ip cef
    ipv6 unicast-routing
    ipv6 cef
    interface FastEthernet1/0
    no ip address
    ipv6 address 2012:AA:12::1/64
    ipv6 ospf 10 area 0
    ipv6 pim rp-address 2012:AA:23::3
    ipv6 router ospf 10
    router-id 1.1.1.1
    end
    hostname R2
    no ip domain lookup
    ip cef
    ipv6 cef
    no ip address
    ipv6 address 2012:AA:12::2/64
    ipv6 ospf 10 area 0
    interface FastEthernet1/1
    no ip address
    speed auto
    duplex auto
    ipv6 address 2012:AA:23::2/64
    ipv6 ospf 10 area 0
    ipv6 router ospf 10
    router-id 2.2.2.2
    end
    hostname R3
    no ip domain lookup
    ip cef
    ipv6 cef
    no ip address
    ipv6 address 2012:AA:23::3/64
    ipv6 mld access-group MULTICAST_GROUP
    ipv6 ospf 10 area 0
    ipv6 router ospf 10
    router-id 3.3.3.3
    ipv6 access-list MULTICAST_GROUP
    permit ipv6 any host FE04::10
    end
    Verification Commands
    show ipv6 mld group
    show ipv6 mld group summary
    show ipv6 pim neighbor
    show ipv6 mroute
    ping ipv6
    References
    IPv6 Multicast Deployment And Configuration Guide
    Implementing IPv6 Multicast
    BagusWahyu
    Community Member
    I'm setting MLD in client network
    rp-address is my server stream address
    i just config like that.. but my video stream with multicast can't forwarding?
    can you help me
