on
10-21-2022
04:57 AM
- edited on
03-22-2023
01:47 PM
by
Tyler Langston
Cisco SD-WAN Version 20.6.3 offers major usability benefits across all use cases. There are enhancement to SD-WAN Infrastructures, SDCI and SD-WAN Security, with innovation and Improvement around Cloud Networking, Operational Efficiency and Application Experiences.
We have put together the table below to give you a quick look at some of the key features in this release.
Feel free to ask any questions about upgrading your Cisco SD-WAN software using the "comment" section below the post.
If you want to stay up to date with our Software Compliance and key feature articles make sure to subscribe to the label 'Software Upgrades'!
Capability |
Feature |
Description |
Pre 20.6.3.1 |
vManage |
SDWAN UX2.0-Phase 1-Cohesion Design |
UX 2.0 Day-0 Quick Connect workflow enables you to create device templates to onboard Wan Edge devices with ZTP/PnP, and to generate bootstrap CLI configuration. It is a new, user-friendly UI and intuitive workflow. |
Previously, you didn’t have a very intuitive vManage GUI workflow, which makes the Day-0 SD-WAN onboarding difficult with an outdated GUI. |
ThousandEyes integration w/ ISR4K, Cat8300, Cat8200 |
With ThousandEyes Integration, vManage can deploy and provision agent software on the router itself. You can even monitor the underlay of SD-WAN fabric, which helps isolate/fix issues quickly. |
Previously, to monitor your network, you were forced to host the agent software on an external x86 appliance, which can be hard to manage, and so is also the case for any additional equipment within the branch. |
Core & Infra |
6+ SLA classes support |
Having 6+ SLA classes per policy gives you additional options in App-Aware Routing. The SLA enhancement also facilitates multi-tenancy deployment, allowing you to push different SLA classes for different tenants. |
Previously, you weren’t able to create more than 6 SLA classes on a policy for your application, which leads you to create a larger number of policies in the fabric and complicates policy management. |
Services |
Reference:
Excelent overview! Very interested in per VPN QoS and Azure addition.
Great Job, continue working on it!!!
Will it be possible to cap/limit bandwidth per VPN?
not use SD-Wan cisco yet, but i'm interesting to learn more
Thanks for detailed overview
I like konws more about thousand eyes + sdwan fabric
We do not use Cisco SD-WAN yet, but Thank you for the overview!
I am interested in more information on the gateway creatin in the Equinix fabric for AWS. Are there any general details available? Or do we research this from the Equinix portal? Thank you!
Like the integration into Equinix fabric, that sounds cool
Thanks for updated information. nice update.
Can not wait to chatch up with SDWAN again in the future with new update..
Thanks for sharing, always nice to get the infos
We haven't implemented SD-WAN, but look forward to it in the future!
Looks pretty awesome.
Is there any isuues if SD-WAN has any flap in it internet connection?
We do not use SD-WAN, but may in the future
Is Java still the prominently supported language for programming?
