i want to share an old tcl script. This script displays information of the ospf-neighbor (Router-ID/Area/State/Address/Interface/DNS of Neighbor) and of all ospf id (for me it was helpful so that i dont forget my vrf-ospf-neighbors :P )
# revision 1.5 2011-12-15 by fholzapfel
# initial revision
# description: This script displays OSPF neighbors, including OSPF area, sorted by process ID
# configure: *ip name-server <ip>
# ios config:
#   * download the file into flash:ospfNeighbors.tcl
#          * configure alias exec on tclsh flash:ospfNeighbors.tcl
#   **invoke with on <ospf-id>
namespace eval DnsHost {
    variable A_RECORD    0x0001
    variable AAAA_RECORD 0x001c
    variable PTR_RECORD  0x000c
    variable CLASS_IN    0x0001
    variable REQ_FLAGS   0x0100
    variable RCODES [list        \
        {No error}                 \
        {Format error}                \
        {Server failure}        \
        {No such name}                \
        {Not implemented}        \
        {Refused}                \
        {Name exists}                \
        {RRset exists}                \
        {RRset does not exist}        \
        {Not authoritative}        \
        {Name out of zone}        \
    proc connect { server proto } {
        if { $proto == "tcp" } {
            if { [catch {set fd [socket $server 53]} result] } {
                return -code error $result
            fconfigure $fd -translation binary
        } else {
            if { [catch {set fd [udp_open]} result] } {
            fconfigure $fd -remote [list $server 53] -translation binary -buffering none
        return $fd
    proc getTid { } {
        expr srand([expr [clock seconds] ^ [pid]])
        return [expr int([expr rand() * 65535])]
    proc getPtr6Req { addr } {
 set shorts [split $addr ":"]
 set zeros 0
 set ptraddr [list]
 if { [llength $shorts] < 8 } {
     set zeros [expr (8 - [llength $shorts] + 1) * 4]
 for { set i [expr [llength $shorts] - 1] } { $i >= 0 } { incr i -1 } {
     if { [lindex $shorts $i] == "" } {
  set ptraddr [concat $ptraddr [split [string repeat "0" $zeros] ""]]
     } else {
  set l [split [lindex $shorts $i] ""]
         set l [concat [string repeat "0" [expr 4 - [string length [lindex $shorts $i]]]] $l]
  for { set j [expr [llength $l] - 1] } { $j >= 0 } { incr j -1 } {
      lappend ptraddr [lindex $l $j]
 lappend ptraddr {ip6} {arpa}
 return [join $ptraddr "."]
    proc getPtrReq { addr } {
 if { [isIP6Addr $addr] } {
     return [getPtr6Req $addr]
        set octets [split $addr "."]
        for { set i [expr [llength $octets] - 1] } { $i >= 0 } { incr i -1 } {
            lappend ptraddr [lindex $octets $i]
        lappend ptraddr {in-addr} {arpa}
    proc isIP6Addr { host } {
 set shorts [split $host ":"]
 if { [llength $shorts] > 8 } {
     return 0
 foreach short $shorts {
     if { $short == "" } {
  continue
     if { [string length $short] > 4 } {
  return 0
     if { ![regexp {^[A-Fa-f0-9]+$} $short] } {
  return 0
 return 1
    proc isIPAddr { host } {
 if { [isIP6Addr $host] } {
     return 1
        set octets [split $host "."]
        if { [llength $octets] != 4 } {
            return 0
        foreach octet $octets {
            if { ![regexp {\d+} $octet] } {
                return 0
        return 1
    proc udp_event { fd } {
        global inData
        global host_event
        set inData [read $fd]
        set host_event "reply"
    proc arrToV6 { addr } {
 set j 0
 set start -1
 set end -1
 set tstart -1
 for { set i 0 } { $i < [llength $addr] } { incr i 2 } {
     set o1 [lindex $addr $i]
     set o2 [lindex $addr [expr $i + 1]]
     if { $o1 == 0 && $o2 == 0 } {
  lappend res 0
  if { $tstart == -1 } {
      set tstart $j
     } else {
  if { $o1 == 0 } {
      lappend res [format "%x" $o2]
  } else {
             lappend res [format "%x%02x" $o1 $o2]
  if { $tstart != -1 && ($start == -1 || [expr $end - $start] < [expr $j - $tstart]) } {
      set start $tstart
      set tstart -1
      set end $j
     incr j
 if { $tstart != -1 && [expr $end - $start] < [expr $j - $tstart] } {
     set start $start
     set end $j
 if { [expr $end - $start] > 1 } {
     set res [lreplace $res $start [expr $end - 1]]
     set res [linsert $res $start ""]
 return [join $res ":"]
    proc lookup { host server proto {ts "A"} } {
        set fd [DnsHost::connect $server $proto]
        if { [catch {set fd [DnsHost::connect $server $proto]} result] } {
        set tid [DnsHost::getTid]
        set flags $DnsHost::REQ_FLAGS
        set class $DnsHost::CLASS_IN
 if { $ts == "A" } {
            set type $DnsHost::A_RECORD
            set reqTypeStr "A"
 } elseif { $ts == "AAAA" } {
     set type $DnsHost::AAAA_RECORD
     set reqTypeStr "AAAA"
        if { [DnsHost::isIPAddr $host] } {
            set type $DnsHost::PTR_RECORD
            set host [DnsHost::getPtrReq $host]
            set reqTypeStr "PTR"
        set qs "\x00\x01"
        set as "\x00\x00"
        set aurrs "\x00\x00"
        set adrrs "\x00\x00"
        set hparts [split $host "."]
        set lkup ""
        foreach part $hparts {
            set len [format "%02x" [string length $part]]
            append lkup [binary format H2 $len]
            append lkup $part
        set query ""
        append query [binary format H4 [format "%04x" $tid]]
        append query [binary format H4 [format "%04x" $flags]]
        append query $qs
        append query $as
        append query $aurrs
        append query $adrrs
        append query $lkup
        append query "\x00"
        append query [binary format H4 [format "%04x" $type]]
        append query [binary format H4 [format "%04x" $class]]
        set reqlen [string length $query]
            set query [binary format H4 [format "%04x" $reqlen]]$query
        puts -nonewline $fd $query
        flush $fd
            set inData [read $fd 2]
            if { $inData == "" || $inData == 0 || ![binary scan $inData S readLen]} {
                close $fd
                return -code error "Error reading reply length from server"
            set readLen [expr $readLen & 0xFFFF]
            set inData [read $fd $readLen]
            close $fd
        } else {
            global inData
     global host_event
            set host_event ""
     # TIMEOUT 1000 ms is hardcoded should be configurable
            after 1000 set host_event "timeout"
            fileevent $fd readable [list DnsHost::udp_event $fd]
            vwait host_event
            close $fd
            if { $host_event == "timeout" } {
                return -code error "Timeout didn't recieved answer"
        if { $inData == "" || $inData == 0 } {
            return -code error "Error reading reply from server"
        if { ! [binary scan $inData SSSS repTid repFlags repQs repAs] } {
            return -code error "Error parsing reply header"
        set repTid [expr $repTid & 0xFFFF]
        set repFlags [expr $repFlags & 0xFFFF]
        set repAs [expr $repAs & 0xFFFF]
        if { $repTid != $tid } {
            return -code error "Transaction ID mismatch"
        set repError [expr $repFlags & 0x000F]
        if { $repAs == 0 } {
            return -code error [lindex $DnsHost::RCODES $repError]
        set answers [string range $inData $reqlen end]
        set aaddrs [list $host $reqTypeStr]
        for { set i 0 } { $i < $repAs } { incr i } {
            if { ! [binary scan $answers SSSIS respName respType respClass respTTL respLen] } {
                return -code error "Error parsing reply body"
            set respType [expr $respType & 0xFFFF]
            set respClass [expr $respClass & 0xFFFF]
            set respLen [expr $respLen & 0xFFFF]
            set answers [string range $answers 12 end]
            if { $respType != $type  || $respClass != $class } {
                set answers [string range $answers $respLen end]
                continue
            set aaddr [list]
            if { $reqTypeStr == "PTR" } {
                binary scan $answers c elen
                set elen [expr $elen & 0xFF]
                while { $elen > 0 } {
                    set answers [string range $answers 1 end]
                    binary scan $answers a$elen elem
                    lappend aaddr $elem
                    set answers [string range $answers $elen end]
            } else {
                for { set j 0 } { $j < $respLen } { incr j } {
                    binary scan $answers c octet
                    set octet [expr $octet & 0xFF]
                    lappend aaddr $octet
     if { $reqTypeStr == "AAAA" } {
  lappend aaddrs [arrToV6 $aaddr]
     } else {
                lappend aaddrs [join $aaddr "."]
        return -code ok $aaddrs
proc get_server { } {
    set cmd "show run | inc ^ip name-server"
    set output [split [exec $cmd] "\n"]
    foreach line $output {
        if { [regexp {([\d\.]+)} $line -> server] } {
            return $server
    set cmd "show host | inc ^Name servers are"
            return $server
    return ""
proc host { args } {
    set args [join $args " "]
    set proto "tcp"
    set ts "A"
    set i 0
    for { } { $i < [llength $args] } { incr i } {
 switch -glob -- [lindex $args $i] {
     -u { set proto "udp" }
     -6 { set ts "AAAA" }
     -* { puts "Unknown option, [lindex $args $i]"
   return -code error
     * { break }
    if { $i < [llength $args] } {
 set host [lindex $args $i]
 incr i
     set dns [lindex $args $i]
 } else {
     set dns [get_server]
    if { $dns == "" } {
        puts "Failed to find a valid DNS server."
        return -code error
    if { $host == "" } {
        puts {usage: host [-u] [-6] address [dns_server]}
        return -code error
    if { [catch {set addrs [DnsHost::lookup $host $dns $proto $ts]} result] } {
        #puts "ERROR: $result"
        #return -code error
    } else {
  set host [lindex $addrs 0]
  set type [lindex $addrs 1]
  if { $type == "A" || $type == "AAAA" } {
   set dns_host [lindex $addrs 2]
  } elseif { $type == "PTR" } {
  set line [split $dns_host "."]
  set name [lindex $line 0]
  return $name
proc printNeighbor {dataName} {
 upvar $dataName data
 global lineFormat
 if {! [array exists data]} { return }
 puts [format $lineFormat $data(ID) $data(AREA) $data(STATE) $data(IFADDR) $data(IFNAME) $data(NAME) ]
proc printProcess {pid} {
 global lineFormat
 set lineFormat "%-15s %-15s %-10s %-15s %-15s %-10s"
 set cmdtext [exec "show ip ospf $pid neighbor detail"]
 if { $cmdtext == "" } { return }
 set cmdtext2 [exec "show ip ospf $pid | in VRF"]
 if {[regexp -nocase {.*VRF (.*)} $cmdtext2 ignore vrf]} {
  puts "\nOSPF neighbors for process ID $pid -> $vrf\n"
 } else {
  puts "\nOSPF neighbors for process ID $pid\n"
 puts [format $lineFormat {Router ID} {Area} {State} {Address} {Interface} {Location} ]
 foreach line [split $cmdtext "\n"] {
  if {[regexp -nocase {neighbor ([0-9.]+).*interface address ([0-9.]+)} $line ignore id ifaddr]} {
   printNeighbor neighbor
   set neighbor(ID) $id
   set neighbor(IFADDR) $ifaddr
   set dns_name [ host $ifaddr ]
   if { $dns_name == ""} {
    set neighbor(NAME) "No PTR-Record set"
   } else {
    set neighbor(NAME) $dns_name
  } elseif {[regexp -nocase {area ([0-9.]+).*interface (\S+)} $line ignore area ifname]} {
   set neighbor(AREA) $area
   set neighbor(IFNAME) $ifname
  } elseif {[regexp -nocase {state is (\w+)} $line ignore state]} {
   set neighbor(STATE) $state
  } elseif {[regexp -nocase {DR is ([0-9.]+).*BDR is ([0-9.]+)} $line ignore dr bdr]} {
   if {[string equal $dr $neighbor(IFADDR)]} {set neighbor(STATE) "$neighbor(STATE)/DR" }
   if {[string equal $bdr $neighbor(IFADDR)]} {set neighbor(STATE) "$neighbor(STATE)/BDR" }
 if {[array exists neighbor]} { printNeighbor neighbor }
proc collectOSPFID {pid} {
 if {$pid == 0} {
  set cmdtext [exec "show ip ospf summary-address | in Process ID"]
   if {[regexp -nocase {OSPF Router .*Process ID ([0-9.]+)} $line ignore id ]} {
    printProcess $id
 } else {
  printProcess $pid
if { $argc == 1 } {
        set id [lindex $argv 0]
} else {
 set id 0
collectOSPFID $id
