SunilKhanna
Level 5
Level 5
Configuring OSPF
Open shortest path first (OSPF) is an IGP developed by the OSPF working group of the Internet Engineering Task Force (IETF).This is test.
OSPF Configuration Task List
OSPF typically requires coordination among many internal routers, area border routers (routers connected to multiple areas), and autonomous system boundary routers. At a minimum, OSPF-based routers or access servers can be configured with all default parameter values, no authentication, and interfaces assigned to areas.
Ø       Enable OSPF
router ospf process-id
network address wildcard-mask area area-id
Ø       Configure OSPF Interface Parameters
ip ospf cost cost
ip ospf retransmit-interval seconds
Ø       Configure OSPF Network Type
ip ospf network {broadcast | non-broadcast | {point-to-multipoint [non-broadcast] }}
http://www.wl0.org/~sjmudd/wireless/network-structure/english/html/figures/ospf.png
