Kundan Prasad
Copy the new IOS image to switch
copy tftp: flash:
verify the image
verify /md5 flash:IOS-NAME
Configure the boot path to new IOS
boot system switch all flash:/PATH
Verify the path
sh boot
Save the config
write
Now you are all set to reboot the device !
Leo Laohoo
copy tftp: flash:
OMfG!  Who's the genius who came up with this method?
There is one big fat flaw with this:  How do you know the file copied is compatible with the appliance?
Copying the BIN file from one switch to another is not only "old school" but also inherently dangerous and will send the appliance into ROMmon.
Leo Laohoo
Please don't reply with a cut-and-paste.
The link you've posted is for an ancient 2950 switch.
The use of the "copy" command to upgrade Cat2K and/or Cat3K have long been out of fashion.  Cisco's Release Notes no longer recommend anyone using this method.
Kundan Prasad
@Leo Laohoo
could you please post the recommended one..
Leo Laohoo
For Cisco IOS, read THIS.
For Cisco IOS-XE, read THIS (IOS-XE version 3.X only).
For Cisco IOS-XE (IOS-XE verison 16.X.X) read THIS.
Kundan Prasad
Thanks @Leo Laohoo
