Resolution
To obtain information on inline power-capable devices connected to ports, issue the cisco-stack-mib command. The specific object within this Management Information Base (MIB) is portInlinePowerDetect, as shown:
portInlinePowerDetect OBJECT-TYPE
SYNTAX TruthValue
MAX-ACCESS read-only
STATUS current
DESCRIPTION "Indicate if the port detects an inline
power capable
device connected to it."
::= { portEntry 24 }
For example, to check the inline power for the IP phone connected to module 4 port 2, refer to this output:
# snmpget -c public switch.cisco.com portInlinePowerDetect.4.2
cisco.workgroup.ciscoStackMIB.portGrp.portTable.portEntry.portInlinePowerDetect.4.2 : true
For more information on the portInlinePowerDetect object, refer to the SNMP Object Navigator.
