How To Configure InterVLAN Routing On Layer 3 Switches
60630
Beginner
(view in My Videos)
In this video we will see an example of how to configure InterVLAN routing on a Cisco catalyst 3550 series switch.
14 Comments
Beginner
Please provide United States-based groups with presenters who have U. S. English as a primary language.  We had to rewind this vid several times at several points because the presenter had such a thick accent and was very difficult to understand.
Thanks.
Beginner
How doyou view theses videos?????
Beginner
Which video format is this? I cannot play the video.
Beginner
It uses Adobe Flash, should play in the browser.
JD
Beginner
The setup looks straight-forward and the video is pretty easy to understand. However, the actual routing step (ip route 0.0.0.0 0.0.0.0 200.1.1.2) is missing from the video. Including that and a better explaination of the routing would make this document and video much better.
Beginner
If you posted a diagram of the network setup, that'd be handy.  For example, which switch ports connect to which host?
Beginner
Crystel Clear presentation .
Even works with out default route.
Thanks buddy.
Beginner
why he using no shut command after configuring switchport access vlan 2 or 3
there is no need on this
you have use NO SHUT when you configuring interface VLAN
Beginner
Great video!
Beginner
Thank you so much!  This was super easy to follow!
Beginner
Great video and easy to follow.  The ip routing at the beginning was most helpful!
Beginner
Beginner
I used Packet tracer to do the testing, however, the 'IP Routing" is not available in any switch in the Packet Tracer.
I do not have physical hardware available for the testing.
If we need this command "ip route 0.0.0.0 0.0.0.0 200.1.1.2", then do we have to have a router on the stub. if a router is needed, then why need layer 3 switch?
PS:
I find that need select Multi-Layer Switch in the Packet Tracer.
It is working now, no need "ip route 0.0.0.0 0.0.0.0 200.1.1.2" command, no need Router -on-Stick
It just works.
Beginner
you don't need a default route.  he is showing inter-vlan routing not how to allow hosts to access the internet.  Since the routes are connected C* there is not need for a default just to speak to each other.
Beginner
Very helpful and clearly explained. Would be nice though if when the video is paused the screen doesn't get blurry.
