Nexus dashboard orchestrator POST API call to add CA cert
Shradha K
Nexus dashboard orchestrator POST API call to add CA cert using URL https://<hostname>/api/config/ndtrustecas/ generates "Error 500: internal server error". Error message says "illegal base64 data at input byte 0"
It seems the API call is not accepting characters of a certificate. When he content of certificate is replaced with string value the certificate is added to NDO.
Can someone help understanding if this is an issue or am I doing something wrong?
Alexander Stevenson
Hi @Shradha K,
I'm not seeing that API endpoint in the API Docs for Nexus Dashboard Orchestrator API Release 4.1(1): https://developer.cisco.com/docs/nexus-dashboard-orchestrator/4-1-1/#!api-reference
Can you please share which version are you running?
