Cisco NDFC Multisite Setup
nkhawaja1
Hey Team,
This is a NDFC Multisite Setup where NDFC is a virtual cluster running latest version.
I got existing Core Routers on each site,
  • Core routers are in production providing L3 Services
  • Core routers connect site-1 and site-2 as well and provide Layer 2
  • provides connectivity to existing campus etc.
Now in NDFC Multisite, we will need to connect Border GW Leaf to these core routers both for Multisite and for L3out.
The question I have are:
  • Do I use “monitor mode”  to add the core routers. If I uncheck the monitor mode and import brownfield, what will be the impact of it to the existing production configuration.
  • Do I use separate interfaces for Multisite and for L3out?
  • Do I use Border GW spine for multisite instead of BGW Leaf?
  • If I use core router as ISN, I can’t add the same devices as core router for External Connectivity (L3 out) and I can’t use the VRF Lite extension workflow, I must manually provision the L3outs.
  • What are the implications of using BGW VPC and also connect hosts to it? I have see it somewhere in the earlier release.
  • In case of Core as ISN, should I use separate VRF on it for multisite and for L3outs? Right now they both are coming into the same default VRF.
Right now, I am using same physical interface for both multisite and L3out, but I must use routed sub-interrace for L3out and routed physical interface for Multisite. I can’t use routed sub interface for multisite
What are your thougts.
nkhawaja1
I figured it all out, no one replied:
  • Do I use “monitor mode”  to add the core routers. If I uncheck the monitor mode and import brownfield, what will be the impact of it to the existing production configuration. ->  I tried both ways. I would prefer "monitor" mode for production core.
  • Do I use separate interfaces for Multisite and for L3out? -> I used same interface, where physical interface is used for multisite and sub-interface is used for L3out
  • Do I use Border GW spine for multisite instead of BGW Leaf?  -> I would prefer BG Spine instead of combining the role to same LEAF.
  • If I use core router as ISN, I can’t add the same devices as core router for External Connectivity (L3 out) and I can’t use the VRF Lite extension workflow, I must manually provision the L3outs.   -> VRF lite workflow worked using same interface for both L3out and Multisite
  • What are the implications of using BGW VPC and also connect hosts to it? I have see it somewhere in the earlier release. -> So far it seems ok in my lab.
  • In case of Core as ISN, should I use separate VRF on it for multisite and for L3outs? Right now they both are coming into the same default VRF. -> I am using separate VRF for underlay and overlays on the core routers.
