DCNM: can not change/edit NTP Settings on Data Center Network Manager LAN Fabric 10.5(1)
sdnscottie
Hello Community,
anyone else frustrated with their Data Center Network Manager LAN Fabric 10.5(1) ?
This is supposed to be the Management Tool for the Nexus Switches, but I've been spending more time reporting TAC-CASES and finding/report bugs, instead of using it as a valued Tool to manage our companies Nexus 7k and 9k Series Switches.
Now I discovered, go on the CLI and enter the command
  # date
And I see my NTP actual time is off 9 hours
I cannot find in the GUI where I can edit my NTP settings ? ( Nothing in the GUI: Administration/Server Settings/... )
Since it's a RHEL OS, I could make changes on the CLI, but that would not be supported ?
Heads-UP:Man, if you've used Cisco Prime over the years and now are trying to get the DCNM up and running and migrate your Nexus n7k, n9k, ASR Switches. Then you are in for a lot of frustration
Can someone help me, point me in the right direction. That would be greatly appreciated.
Kind Regards, Scottie
aortizhe
Hi @sdnscottie, maybe is too late for this reply but
The Release DCNM 10.5(1) version doesn't exist,
Are you refering to 11.5(1)?
You can update NTP from GUI from 11.5(1) onwards:
Ability to update network parameters
Cisco DCNM allows you to modify few network parameters from the Web UI. Modifying these overwrite the previously configured parameters. Choose Cisco DCNM Web UI > Admin > DCNM Server > Customization > Network Preferences to modify the DNS, NTP, and addition or removal of static routes over the out-of-band (eth1) and inband (eth2) interfaces.
https://www.cisco.com/c/en/us/td/docs/dcn/dcnm/1151/release-notes/cisco-dcnm-release-notes-1151/new_features.html?bookSearch=true
https://www.cisco.com/c/en/us/td/docs/dcn/dcnm/1151/configuration/lanfabric/cisco-dcnm-lanfabric-configuration-guide-1151/administration.html#concept_gq1_hwr_xnb
If it is DCNM 10.4(2) then you have to do it through cli with the CentOs/RHEL commands and then restart DCNM service
aortizhe
Hello aortizhe,
thank you, that was helpful. Yes, we are currently using 11.5(1)
We solved the problem using the CLI:
appmgr set-timezone CET
appmgr update network-properties session apply
appmgr stop all
appmgr start all
