09-20-2021 12:35 PM
I am hearing that multicast is not supported over the Nexus switches like the 7k with vpcs? Is this true? Thanks for your comments or tips...
Solved! Go to Solution.
09-21-2021 03:47 AM
Hi @craneman1
If by multicast over vpc, you mean multicast routing, then you should check this document:
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/118997-technote-nexus-00.html
You will see it's mentioned that
However, you can have PIM adjacency over vPC Peer-link.
If on the other hand, you are refering to L2 multicast and/or IGMP snooping, then this one is supported. For more details about it you can check the config guide: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/multicast/config/cisco_nexus7000_multicast_routing_config_guide_8x/m_igmp_snooping.html
Stay safe,
Sergiu
09-21-2021 03:47 AM
Hi @craneman1
Stay safe,
Sergiu
09-22-2021 03:55 AM
Thanks very helpfull and I think we might need to upgrade to version 8!
