1171
sdnscottie
Beginner
Cannot Filter on ( Unreachable ) Nexus Switches
Hi DevNet Team for DCNM,
Status column is only filterable on ( Warnings, Unmanaged, OK ) but "Unreachable" is possible and if we filter on "Unreachable",
then "No Data Found" !
Come on Guys, This is a major oversight.
Can someone please provide me some feedback.
This is a Cisco product and not a MSFT product.
Kind Regards, Scottie
1 ACCEPTED SOLUTION
Sounds more like a bug: feature is there ("Unreachable" exists as a filter), but not working (if filter is selected, returned data is "no data found".
Cheers,
Sergiu
3 REPLIES 3
bigevilbeard
Hello  @sdnscottie this isn't my area of knowledge but sounds like this would need to be a feature request. I would recommend you open a Cisco TAC case first. Then, locate your account team and report the ticket number and the wish for the Enhancement Request. The technical side of the account team, meaning, SE (Systems Engineer) or CSE (Consulting Systems Engineer) should then be able to contact the business unit (BU) on your behalf.
Hope this helps.
Cheers,
Sergiu
Hello Sergiu,
yes that is right on spot. Cisco TAC replied on friday,  the bug fix is in the DCMN version 12, due out Ende August.
thanks for your reply.
Scottie
Create
Recognize Your Peers
Content for Community-Ad
