Highlighted
Beginner
Capacity Question about N77,M3 Cards
According to following links;
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/bulletin-c25-736584.html
Cisco Nexus 7700 M3-Series 12-Port 100 Gigabit Ethernet Module provides 1.2Tbps throughput and Cisco Nexus 7700 M3-Series 24-Port 40 Gigabit Ethernet Module provides 960Gbps and...
Also in the datasheets it was noted  N77-C7710-FAB3 provides 464Gbps/Slot throughput.
I wonder are these values are in "Full-Duplex"or "Half-Duplex". In other word Do I Have Line-Rate Throughput in both direction on following LCs on N77:
- N77-M312CQ-26L
- N77-M348XP-23L
- N77-M324FQ-25L
Consider using the mention Fabric Card. Is there any license required for having the throughput. According to following link, we do not:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/licensing/guide/b_Cisco_NX-OS_Licensing_Guide/b_Cisco_NX-OS_Licensing_Guide_chapter_01.html
In Summary for example Do we have 100Gbps on TX and 100Gbps in RX on all ports of N77-M312CQ-26L?
Thank you
Peyman
0 REPLIES 0
