Devnet NX-OS
ShishirDash5204
I am not able to run the pyang on the windows machines to get the tree structured models.
After installing pyang package with pip install pyang,  I am getting the following error:
'pyang' is not recognized as an internal or external command,
operable program or batch file.
What's the possible solution to that?
@ShishirDash5204 see this repo https://github.com/joshmatt-dev/pyang-for-windows
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
qsnyder
How are you invoking `pyang` from your Windows machine?  Are you doing so through the command prompt or Powershell prompt?  If so -- please try something a bit more graceful/sane when it comes to Python (git-bash or so).
Please see this thread for context:
https://github.com/mbj4668/pyang/issues/310
Thanks. I am using git bash, but the result is the same pyang :command not found.  Could you please suggest a more graceful way to install Pyang?
thanks
