N7K - DHCP Relay Hardware programming error
maverick0
Guys,
I am facing an issue in the N7K where I trying to configure the ip dhcp relay address X.X.X.X on a VLAN interface, but I getting the following error message:
ERROR: hardware programming failed. Reason: Tcam will be over used, please enable bank chaining and/or turn off atomic update. If bank-chaining is enabled on other modules and this is a new linecard insertion, please enable bank-chaining prior to reloading this module.
Thanks!
