05-25-2021 08:25 AM
Planning to upgraded these switches from 7.0(3)I7(8) to new 9.3.7. Would like to confirm if I can perform this upgrade in a single jump. If I'm understanding documentation correctly I should be able to do this. Can anyone confirm.
Upgrading from a 7.x release to a 9.3(x) release may require more than a single hop. The following section
describe the upgrade paths required.
The following are the upgrade paths from previous 7.0(3)F3(x) releases:
• Release 7.0(3)F3(x) -> Release 7.0(3)F3(4) -> Release 9.3(x)
Solved! Go to Solution.
05-27-2021 06:23 AM
Good to know all went well. can we mark this as solution if this is completed.
05-25-2021 08:34 AM
there are some known issue and caveats when you upgrading from 7.X to 9.3 check is this effects your environment.
if you have test device i would suggest to test in that before you upgrade live if that feature effecting you.
05-27-2021 06:16 AM
Thanks for the info. I did proceed to perform the upgrade and the upgrade was successful with no issues.
Thanks again.
Richard
05-27-2021 06:23 AM
