NFVIS doesn't respond from CIMC
melechow
hi,
I have ENCS5412 with CIMC (BIOS 2.12, FW 3.2(11.4). I was running NFVIS ver.4.4.2 and decided to change to new version 4.10.1.
My plan was to make a clean re-install - map iso with 4.10.1 7 and reboot the host. After the restart the NFVIS doesn't respond at all (neither KVM nor SOL console). Do you have maybe some suggestion what might be wrong ? In the Summary page it says "Memory test in progress" - it looks like it stops during the initialization process and then there's no response. The power reboot didn't help.
0 Replies 0
