Hello Friends,
Pls am suppose to write about Project management risk in IT, i need to know few things, if any one knows a real example of any firm/company that must have had a failed project, and the associate risk they took that made the project not to meet his objectives
pls
hello,
your question is not very clear. still i'm giving some inputs,
if we consider a project, if it's a new implementation or an upgrade the implementer should have a proper plan let's say the scope of work, like for example you need to consider everything if you are going to mount a L2 switch you have to mention in scope of work, like "Rack mounting the Switch" or afetr that if you are creating a vlan that also should be the part of scope of work, visit the site before implementing the hardwares, check the power and rack option's, if something is not there convince the customer properly.
please reply with your queries
I was given this assignment:
Case study a failed project in IT and the associated risks taken that led to the project not meeting objectives.
thanks for ur quick response
