ron.whitt
Hello experts,
I am trying to install the ncs-5.3.1.1-cisco-etsi-nfvo-4.2.0-bundle for NSO (version 5.2.0.3, local install under ~/ncs-run)
I can get all the other packages to load and compile, but for the cisco-etsi-nfvo package, there isn't a Makefile under /src.
I tried loading the packages without compiling the cisco-etso-nfvo package, but NSO throws this error:
>>> System upgrade is starting.
>>> Sessions in configure mode must exit to operational mode.
>>> No configuration changes can be performed until upgrade has completed.
>>> System upgrade has been cancelled.
Error: Internal error: {failed,
{recompile_needed,
"./state/packages-in-use/1/cisco-etsi-nfvo/load-dir/etsi-nfv-descriptors.fxs"}}
But... no makefile... no compile.
Any  help or guidance would be appreciated.  if someone has the makefile, maybe post that and I'll copy it into the build.
1 Comment
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
