cisco-staros-cli-5.22 - nso 4.2.1
485
Hi Expert,
I got this error when I try to sync-from from one of my device:
anthony@ncs# devices device mv-lab sync-from
result false
info External error in the NED implementation for device mv-lab: read timeout after 20 seconds, blocked on "\r\n" when waiting for "Continue\\?\\[confirm\\]" | "Are you sure? \\[Yes|No\\]:" | "\\A[^\\(#|>|%) ]+(#|>|%)[ ]?$"
/var/log/ncs/ncs-java-vm.log
<WARN> 08-Jan-2020::17:22:54.032 NavuContextBase Ned-Worker-Thread-(cisco-staros-cli-5.22:cisco-staros-cli-5.22)-0: - No case selected and no default
<ERROR> 08-Jan-2020::17:23:23.003 NedWorker Ned-Worker-Thread-(cisco-staros-cli-5.22:cisco-staros-cli-5.22)-0: - NedWorker error for ned_get_trans_id
com.tailf.ned.SSHSessionException: read timeout after 20 seconds, blocked on "\r\n" when waiting for "Continue\\?\\[confirm\\]" | "Are you sure? \\[Yes|No\\]:" | "\\A[^\\(#|>|%) ]+(#|>|%)[ ]?$"
at com.tailf.packages.ned.nedcom.connector.SSHSessionExt.expect(SSHSessionExt.java:160)
at com.tailf.ned.SSHSession.expect(SSHSession.java:545)
at com.tailf.ned.SSHSession.expect(SSHSession.java:528)
at com.tailf.packages.ned.staros.CiscoStarosNedCli.executeShowCommand(CiscoStarosNedCli.java:1344)
at com.tailf.packages.ned.staros.CiscoStarosNedCli.getTransId(CiscoStarosNedCli.java:1033)
at com.tailf.ned.NedWorker.dorun(NedWorker.java:1911)
at com.tailf.ned.NedWorker.run(NedWorker.java:315)
question: what command is triggered (by NSO) during "sync-from" command (that may trigger this error)?
I SSH to the device directly and i didn't get Continue\\?\\[confirm\\] prompt
3 Comments
as per com.tailf.packages.ned.staros.CiscoStarosNedCli.executeShowCommand(CiscoStarosNedCli.java:1344)
    private String executeShowCommand(NedWorker worker, String showCommand,
            boolean isCheckSum)
            throws IOException, SSHSessionException, NedException {
        setReadTimeout(worker);
        session.print(showCommand + "\n");
        session.expect(showCommand, worker);
        if (isCheckSum) {
            session.expect("Generating configuration ...", worker);
        NedExpectResult expectRes = session.expect(PLW_EXEC_PROMPT, worker);
        if (expectRes.getHit() == 1) {
it looks like this CLI is causing error:
anthony@ncs# devices device mv-lab live-status exec show config checksum
Error: External error in the NED implementation for device mv-lab: read timeout after 20 seconds, blocked on "\r\r\n  Generating configuration ...\r\n" when waiting for "Continue\\?\\[confirm\\]" | "Are you sure? \\[Yes|No\\]:" | "\\A.*\\(.*\\)(#|>|%)[ ]?$" | "\\A[^\\(#|>|%) ]+(#|>|%)[ ]?$"
when I run the command directly on the device, i didnt get error. but the output is coming after 20s
[local]mv-asr5k# show config checksum
Wednesday January 08 15:05:59 PST 2020
  Configuration checksum:       06426ee16aad86e7858f92a73d10b4fd
[local]mv-asr5k# time
Wednesday January 08 15:06:33 PST 2020
question: is there any way to increase NSO timer (of waiting an output)?
First of all, you probably want to turn on ned-traces for this kind of troubleshooting. Second, yes, you have both read-timeout and write-timeout available on the device (as well as in global-settings).
thanks @vleijon  - increasing read timeout solve my problem
