Sorry for the delay but I had to do some research and go back to the training team to answer your question. Hope this help
Here is what I got:
NSO201 was created as a replacement for NSO100 which was EoLed in May 2018. The NSO100 course datasheet has been removed. A detailed summary of the changes is provided below.
Main changes between NSO100 (now EoL) and NSO201:
·Module 1 is completely restructured for easier introduction into the course. High-level explanation about the NETCONF and
YANG is added to describe the basic concepts of NETCONF and YANG at the beginning.
·Additional lesson Resources and Training is added at the end of Module 1 to include additional resources and training options for students.
·Lab topology is extended with one Cisco NX-OS and one Cisco IOS switch to support additional use cases.
·In Module 2: Model to Model mapping lesson is rewritten using the VLAN service. Lesson describes how Template processing logic creates device-specific configurations from an XML template, how Mapping logic correlates with Template processing. The explanation is based on the VLAN example from the FASTMAP topic
·Additional lab on how to create a simple Loopback template service.
·Additional lab on how to create a VLAN template service.
·Module 4 now includes the NSO Programmability Introduction lesson. Lesson describes which language bindings can be used and how to extend the default mapping logic. It explains how service processing with Python works. New example added of Python and template based service. VLAN SVI service used.
·Additional lab on how to create an L3VPN template service
·Additional lab on how to create an SVI python-template service using Python mapping logic.
·New Module 5 added.
·New lesson Scalability and Performance. It describes HA Cluster communication, Layered Service Architecture and how to address performance limitations
·New lesson Components and Function Packs. It describes common concepts and built-in components. It explains how Function Packs extend NSO functionality and how to do NFV Orchestration with NSO.
·Additional lab on how to use NSO REST API with Postman. It shows how to retrieve data of an existing device, create a new device and delete a device. It shows how to retrieve data of an existing service, create a new service, delete a service and issue commit dry-run query using NSO REST API.
Hi All!
Hello! Does NSO 5.4 support Alarms for HA events? For example: failure of master or slave node..? I saw one conversation which says tailf-hcc used to generate node-failure alarm atleast until nso 5.3.. but I can’t find any alarm type for HA...
view more
One of my service-packages got a broken xml template.If I start NSO with "--with-package-reload" the service package with the broken xml template loads into NSO and NSO shows "oper-status up" for this package.But if I run "package reload" via NCS_CLI agai...
view more
Hello,I succeed to build netconf ned using fetch-module-list, which will fetch all yang models existing on the device. But I need to manually put the yang models (specific yang models I need) on NSO and NOT fetch them from the device. A document says I co...
view more
Dears,used NSO ==> 5.3 i have created a simple python action that lists the interfaces of the device based on the type u choose as shown below, but when i click run it redirects me to the below page so i need to refresh page to see the outputpytho...
view more
Hi all, during the compile of Juniper NED, I encounter an issue from Erlang compiler.It looks like, that Erlang cannot find a file.The directory is owned by user root inside a Docker container. Maybe someone has a hint to fix it. OS: ...
view more
