umap same password issue in version 5.3
RehabRezek73161
Hello
I have an issue that when I use  umap with  same-pass in authgroup   and try even to connect to device or  run application i made by  mappi  it doesn't work  and below error is appear
i'm sure that password is correct
so i should change to remote password to work
 any help ?
thanks
ramkraja
Did you actually authenticate yourself somehow?
If you just do "ncs_cli -C", you will get a CLI session, but it is not authenticated - which means, there will be no 'local password' for this session.
Try connecting to the CLI port (2024 by default) using SSH.
/Ram
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
