additional fields to device-groups
Hi all,
we would like to add some customer fields to device groups such as realm and systems and some others, i assume devices groups has its own yang model some where.
1 is this a valid approach where we just add new leaf's to that yang model
2 where is the file that i would need to edit for device groups
Yale
yfherzog
You don't actually need to modify the YANG module itself for that.
You should use the augment statement from your own file in order to extend sections of the data model written in other files.
This is a good practice, but some care needs to be taken in order to keep the validity of existing nodes.
You should be able to add a block similar to the one below to your YANG module (haven't tested it):
  import tailf-ncs {
    prefix ncs;
  augment /ncs:devices/ncs:device-group {
    leaf realm {
    list system {
Yftach
yfherzog
  import tailf-ncs {
    prefix ncs;
    leaf realm {
    list system {
Yftach
Hi, when you say my own yang file which file would that be ? that yang file that is part of a service ?? Thanks Regards Yale
It's up to you.
It can be inside a service package that you already have, or inside another dedicated package, or inside some sort of common-library package where you'd keep additional generic stuff (YANG, code, etc.).
It all depends on what makes most sense for your solution.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
