After setting up LDAP and logging to webui seeing error-Method denied
Shashank Srivastava
After setting up LDAP authentication on a VM instance with NSO in system install configuration when I am tyring to login to webui I see a popup saying 'Method denied'. Also, NSO version on the webui says Undefined, even the packages are visible through cli but they are not visible on the UI. Please see attached screen captures.
Any suggestion/inputs to resolve this is appreciated.
Shashank Srivastava
rogaglia
You should check your logs to give more clues.
