Highlighted
Are their any examples of NSO tfcp:policy rule syntax?
I'm having no success in finding examples of how to write a tfcp:policy rule syntax in the ncs_cli or the NSO web interface?
Would someone point me in the right direction or provide some simple examples?
1 ACCEPTED SOLUTION
Highlighted
Interesting...
So... i went and tried this (yours...) it fails...
Went to look for more details... (tail -f *.* in logs ) and all that... saw some errors..
17-Aug-2017::10:58:46.491 Evaluating XPath for policy: foo:
  /ios:interface[type = 'GigabitEthernet']
keypath not found: "/ios:interface"
Decided (after trying a few things) to look for more guidance...
Noticed that there is a section in the NSO Users Guide (e.g. nso_user_guide-4.4.2.pdf)
on page 85.... This guide provides an example that differs somewhat from the one in the YANG file
Example 19. Policies
ncs(config)# policy rule gb-one-zero
ncs(config-rule-gb-one-zero)# foreach /ncs:devices/device[starts-with(name,'ce')]/config
ncs(config-rule-gb-one-zero)# expr ios:interface/ios:GigabitEthernet[ios:name='0/1']
ncs(config-rule-gb-one-zero)# warning-message "{../name} should have 0/1 interface"
ncs(config-rule-gb-one-zero)# commit
zork(config-rule-gb-one-zero)# top
I "tested" it...  modified slightly to have "error-message" instead of "warning-message"
admin@ncs% switch cli
admin@ncs(config)# policy rule foo
Value for 'expr' (<string>):
admin@ncs(config-rule-foo)# foreach /ncs:devices/device[starts-with(name,'c')]/config
admin@ncs(config-rule-foo)# expr ios:interface/ios:GigabitEthernet[ios:name='0/1']
admin@ncs(config-rule-foo)# error-message "{../name} should have 0/1 interface"
admin@ncs(config-rule-foo)# commit
Commit complete.
trying this out...
admin@ncs(config)# no devices device c0 config ios:interface GigabitEthernet 0/1
admin@ncs(config)# validate
Failed: c0 should have 0/1 interface
admin@ncs(config)# commit
Aborted: c0 should have 0/1 interface
admin@ncs(config)#
that seems to work...
(have not tried to re-format the MTU example you had...)
cheers
gregg
9 REPLIES 9
Highlighted
Hi Eric
never tried this - but...
a) found the YANG file... often times good/interesting info is directly incorporated here...
E.g. (for me)
./nso-4.4.2/src/ncs/configuration_policy/tailf-configuration-policy.yang
which includes:
  description
    "This module defines configuration policies.  A configuration policy
     enforces custom validation rules on the configuration data.
     These rules assert that the user-defined conditions are always
     true in committed data.  If a configuration change is done such
     that a policy rule would evaluate to false, the configuration
     change is rejected by the system.";
and:
        description
          "An XPath 1.0 expression that is evaluated when the configuration
           is validated, either when a validate operation is performed,
           or at commit time.
           The result of the expression is converted to a boolean using
           the standard XPath rules.  If the result is 'false', validation
           fails with an error or a warning, as specified in the 'action'
           choice.
           For example, in order to verify that no ethernet interface has
           a MTU other than 1500, the following expression can be given:
     foreach '/interfaces/interface[type = ethernet]'
     expr 'mtu != 1500'
     error 'Ethernet interface {name} must have MTU 1500'
So i tried that... (had to use " and not ')
admin@ncs% set policy rule foo foreach "/interfaces/interface[type = ethernet]" expr "mtu != 1500" error-message "Ethernet interface {name} must have MTU 1500"
[ok][2017-08-17 08:48:20]
[edit]
admin@ncs%
admin@ncs% commit
Commit complete.
[ok][2017-08-17 08:48:35]
[edit]
admin@ncs%
admin@ncs% show policy rule
rule foo {
    foreach       "/interfaces/interface[type = ethernet]";
    expr          "mtu != 1500";
    error-message "Ethernet interface {name} must have MTU 1500";
[ok][2017-08-17 08:48:50]
[edit]
admin@ncs%
admin@ncs% delete policy rule foo
[ok][2017-08-17 08:49:52]
[edit]
admin@ncs% commit
Commit complete.
[ok][2017-08-17 08:49:53]
[edit]
admin@ncs%
perhaps this helps...
Cheers
gregg
Highlighted
This can be very useful at times.
And, you forgot single quotes around 'ethernet' (or whatever value you want to compare against, e.g. 'ethernetCsmacd') in the foreach expression.
Highlighted
Thanks Jan
good comment - i just pulled the example from the YANG file description field... - to help the original poster.
didn't actually try it fully -- but it is an interesting !
thanks
gregg
Highlighted
Thanks for the quick replies
I've been trying to test (fail) the policy by the following:
foreach       "/ios:interface[type = GigabitEthernet]";
expr          "mtu != 1500";
set devices device s00-rtr config ios:interface GigabitEthernet 0/0/3 mtu 4400
... but it allows it to configure and commit.
Any ideas?
Highlighted
Interesting...
Commit complete.
trying this out...
admin@ncs(config)#
cheers
gregg
Highlighted
SUPER APPRECIATE!!!!
Your latest gets me through the front door.
Highlighted
awesome!
(I learned new things today too!  thanks for asking the question)
Highlighted
hi Eric,
Here some of the examples I use for IOS/XR/Juniper in my demos:
1) I force the loopback 0 to never be in shutdown mode.
2) I force the ISIS metric to be always greater than 99.
I hope this helps!
Roque
tfcp:policy {
    tfcp:rule loopback-up-ios {
        tfcp:foreach  /devices/device;
        tfcp:expr     not(config/ios:interface/ios:Loopback[ios:name='0']/ios:shutdown);
        tfcp:error-message "Loopback 0 is cannot be shutdown";
    tfcp:rule loopback-up-juniper {
        tfcp:foreach  /devices/device/config/junos:configuration/interfaces/interface[name='lo0'];
        tfcp:expr     not(disable);
        tfcp:error-message "Loopback 0 cannot be shutdown";
    tfcp:rule loopback-up-ios-xr {
        tfcp:foreach  /devices/device/config/cisco-ios-xr:interface/Loopback[id='0'];
        tfcp:expr     not(shutdown);
    tfcp:rule isis-metric-juniper {
        tfcp:foreach  /devices/device/config/junos:configuration/protocols/isis/interface/level/metric;
        tfcp:expr     .>99;
        tfcp:error-message "ISIS metric MUST be larger than 100";
    tfcp:rule isis-metric-iosxr {
        tfcp:foreach  /devices/device/config/cisco-ios-xr:router/isis/tag/interface/address-family/ipv4/unicast/metric;
        tfcp:expr     .>99;
    tfcp:rule isis-metric-ios {
        tfcp:foreach  /devices/device/config/ios:interface/GigabitEthernet/isis/metric;
        tfcp:expr     .>99;
Highlighted
Thanks again, you've been a HUGE help!!!
