Associating NETSIM devices with NSO
Allase
I tried this command :
~/nso-5.3/examples.ncs/getting-started/using-ncs/1-simulated-cisco-ios$ ncs-setup --netsim-dir $HOME/netsim --dest .
But I have this error message :
/nso-5.3/bin/ncs-netsim: line 897: xsltproc : command not found
When a Tried to start ncs, I have this message :
CDB boot error: Init transaction failed to validate: /ncs:devices/device{c0}/device-type : must configure one of: snmp, cli, generic, netconf
Daemon died status=10
Can you help please ?
lmanor
First, It appears you are missing the xsltproc command in your linux. Linux package libxslt, which I believe is also dependent on libxml.
lmanor
I installed xsltproc Package :
sudo apt-get install -y xsltproc
It's OK now !!! Thank you
