Not sure if this is solved yet, long times since your post, but I can help me if you provide me with the raw trace from your run.
Do this in ncs_cli -C:
devices global-settings trace raw
devices disconnect
devices connect
devices device <devname> live-status exec any "the command which triggers the menu"
Then attach the .trace file here (after stripping any private info from show running). I can then check how it all looks.
Or alternatively, if you tell me what device type you got, what command you running and how to trigger it all.
Lennart
