CSR1000v - Invalid Value for Multicast route-limit
Hello everyone,
I have a problem:
When i try sync my CSR1000v with NSO i get this error.
i dont any Multicast configuraction in my CSR1000v, but the yang model set by default this value
Is this problem familiar to you?
Thanks for your help
Best regards
Kevin Rengifo
snovello
Hello Kevin,
the problem you describe may be an issue with the device, i.e. simply the device is reporting this error. I would turn on ned tracing for this device to check that.
I've looked at the yang model here revision 2019-07-01 and this value is in range but there is no default for this leaf. So its not purely a yang issue, but could be something like a mismatch between the capability of the device and what the model describes.
Realize I'm being a little vague here, but its hard to tell for sure from the info you posted.
You mention that you are not even using multicast. In that case a quick solution may be to  exclude this yang module from the NED you use.
Best regards
Stefano
