01-18-2018 08:44 AM - edited 03-01-2019 04:04 AM
Hello community,
I've created a NSO infrastructure service which pushes the basic BGP configuration to my devices, and establishes the needed interior peerings between them.
On a few devices, I manually added external BGP neighborships.
What can I do to prevent the infrastructure service from removing these manual sessions when it is re-deployed? Without modelling these BGP sessions in the service if possible.
Thank you,
Sylvain
Solved! Go to Solution.
01-18-2018 11:02 AM
Hi Sylvain,
In general, NSO should only remove what it added unless you explicitly tell it to delete something.
-Dan
01-18-2018 11:02 AM
Hi Sylvain,
-Dan
01-19-2018 11:46 AM
Hi Dan,
Thank you. Thanks to your response I understood the behavior I was observing was wrong. Probably some old dependencies due to successive code upgrades. I've cleared the configurations and re-deployed the current packages, and it's now working as expected.
Sylvain
