Deref in a when statement
Johan Nemitz
I have the following yang model:
    leaf device {
      tailf:info "Name of the Device to configure";
       type leafref {
       path "/ncs:devices/ncs:device/ncs:name";
    leaf test {
      type leafref {
      path "deref(../device)/../ncs:device-type/ncs:cli/ncs:ned-id";
    container device-model {
     when "deref(../device)/../ncs:device-type/ncs:cli/ncs:ned-id = 'cisco-ios'";
     tailf:info "Model of the device";
       choice device-model {
         leaf Catalyst-3560x {
           type empty;
        leaf Catalyst-4510 {
          type empty;
//   must "deref(../device)/../ncs:device-type/ncs:cli/ncs:ned-id = 'cisco-ios'" {
//     tailf:dependency "/ncs:devices/ncs:device/ncs:device-type/ncs:cli/ncs:ned-id";
Using NSO version 4.6 with the CLI, when I set data in the model, selecting a device with a ned-id = 'cisco-nx' the test leaf correctly returns only the value cisco-nx.  However, I also incorrectly, or at least not the behaviour I am looking for, see the device-model container.  How do I use a deref in a when statement, or must statement(with the correct tailf:dependency) so that I either don't see the device-model container when selecting a non cisco-ios device, or at least throw the correct error on a must.  Neither seems to work the way I have defined it above
Is this possible?
Johan
0 Replies 0
