Expected result in Python of an exists() on an boolean leaf
lweddewer
Level 5
Level 5
I want to use a leaf type boolean:
leaf active {
type boolean;
What is the expected result of the exists() function a leaf of type boolean?
I get a error message "'bool' object has no attribute 'exists'."
That's not what I expect! :(
Lothar
tbjurman
Hi Lothar,
Reading a boolean leaf using maagic will return True or False (native Python type) if the leaf exists.
If it doesn't exist the return value will be None.
/Tomas
tbjurman
Hi Lothar,
/Tomas
Hi Tomas,
thank you for your reply.
I was somewhat struggled because I changed a former implementation based on a empty leaf towards the a boolean because I needed the three stats "not set", "true" and "false".
Reading the Maagic API discription coming with nso I expeted to handle a boolean as a NonEmptyLeaf() Class object.
Regards Lothar
