External authentication tacacs issue
previousqna
Level 5
Level 5
I'm on site in a customer system configuring  external authentication in TACACS with NSO version 4.3.1
I'm always getting this output:
    • But I can see in the TACACS system that the user is being correctly authenticated
   This correct authentication is partly confirmed by the ncs.log:  (made 3 attempts… second one was with incorrect password)      But audit.log is always logging this has a failure:     Here's the external authentication script I'm using:
    • Yellow line below in present in the ncs.log confirming successfully authentication in Tacacs.
    • Any thoughts on what I've done wrong in NSO?
#!/usr/bin/perl
use Authen::TacacsPlus;
$line = <>;
$line =~ tr/[]//d;
@input = split(/;/, $line);
$username = $input[0];
$password = $input[1];
my $filename = '/opt/ncs/ncs-4.3.1/tacacs_auth.properties';
chomp $password;
open my $in, '<:encoding(UTF-8)', $filename or die "could not open file '$filename' $!";
while(<$in>){
($name,$val)=m/(\w+)\s*=(.+)/;
        $properties{$name}=$val;
close $in;
print $username;
chomp $properties{"SERVER"};
chomp $properties{"SECRET_KEY"};
chomp $properties{"USERS_GROUP"};
chomp $properties{"USERS_HOMEDIR"};
if(!$properties{"SERVER"} || !$properties{"SECRET_KEY"}){
        die("SERVER or SECRET_KEY are undefined in tacacs_auth.properties");
if(!$properties{"USERS_GROUP"} || !$properties{"USERS_HOMEDIR"}){
        die("USERS_GROUP or USERS_HOMEDIR are undefined in tacacs_auth.properties");
$tac = new Authen::TacacsPlus(Host=>$properties{"SERVER"},Port=>'49',Key=>$properties{"SECRET_KEY"});
unless ($tac){
        print "abort ",Authen::TacacsPlus::errmsg(),"\n";
        exit(1);
if ($tac->authen($username,$password)){
        print "accept $properties{'USERS_GROUP'} 1003 1003 27 $properties{'USERS_HOMEDIR'}\n";
} else {
        print "reject ",Authen::TacacsPlus::errmsg(),"\n";
$tac->close();
previousqna
Level 5
Level 5
Sorted… stupid stupid mistake!
Solution with explanation for anyone search this in the future.
If you look at the ncs.log :
The reply must be in this format: accept $groups $uid $gid $supplementary_gids $HOME\n
The one in the log is not following this rule, it contains a leading: 43500097
This print line was added by the customer to script… I totally missed that for the last 3 hours!
(Remove the line marked in orange bellow in the script, and it works)
I can see you are mapping a user to a group in a local tacacs_auth.properties file. Is it possible to store group information on the tacacs server?
